Thread Closed
Hvac calculation
Share Thread Thread Tools
May23-10, 02:52 AM   #1
Hvac calculation
Dear all
I am working in MEP field but no experience so I need your helps how find out an area cfm calculation and what is the ton of Ac given, what is the power how to find this calculation ..
BTU/HR - British Thermal Unit /Hr.
CFM - Cubic Feet per Minite
TMBH - ?
SMBH - ?
what is mean by TMBH and SMBH ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
May23-10, 09:18 AM   #2
Mentor
Welcome to PF.
If you're working in the HVAC field, don't you have a more experienced engineer to mentor you? There is no other effective way to become an HVAC engineer. Anyway....
The capacity required (CFM at a certain temperature) is usually calculated using software for the internal and skin (walls, windows) load and fraction of fresh air and its temperature. Unless it is 100% outside air and a high volume (like for a lab), then it is just calculated using a psychrometric chart.
A ton of cooling is 12,000 BTU/hr
TMBH is total MBH (MBH is 1000 BTU/hr)
SMBH is sensible MBH (the part of the capacity related to temperature change, not condensation of water.
Thread Closed
Thread Tools
Similar Threads for: Hvac calculation
Thread Forum Replies
Energy Efficiency - HVAC Mechanical Engineering 20
Entry Level HVAC Engineer Mechanical Engineering 4
Mechanical Engineers in HVAC/MEP work Career Guidance 0
HVAC Industrial Placement General Engineering 6
