Cross Section of Water Flowing Down Vertical Pipe: The Mystery Unveiled
The discussion revolves around the behavior of water flowing down a vertical pipe of constant cross-section compared to water flowing in a waterfall. Participants explore the implications of fluid dynamics, particularly focusing on velocity, cross-sectional area, and the effects of gravity on flow rates.
  • Some participants assert that in steady flow, the mass flow rate must remain constant, which implies that if the cross-section of the pipe is constant, the velocity of water should not increase due to gravity.
  • Others challenge this by questioning why the velocity does not increase in a vertical pipe, suggesting that the behavior of water in a waterfall is different from that in a rigid pipe.
  • A participant mentions that water will not flow as fast as a stone dropped from the same height, implying differences in flow dynamics.
  • One participant proposes that if water were to leave the sides of the pipe, it would create a low-pressure region that would affect the flow, indicating that the water is not in free fall but influenced by the pressure of the entire column.
  • There is a suggestion that a pipe designed to alter its diameter could demonstrate different flow characteristics, indicating a potential design challenge.
Participants express differing views on the behavior of water in a vertical pipe versus a waterfall. There is no consensus on why the velocity does not increase in the pipe, and the discussion remains unresolved with competing perspectives on fluid dynamics.
Participants reference concepts such as conservation of mass and incompressibility, but the discussion does not resolve the implications of these principles in the context of the specific flow scenarios being compared.
R Power
hi
We all know when velocity of fluid increases then cross section decreases for same mass flow rate and this can be well seen at water flowing from a height as in waterfalls.
But why this doesn't happen when water flows down through a vertical held pipe of constant cross section. Well you may say that since cross section of pipe is constant so it's velocity will remain same but why then velocity doesn't increase due to gravity?
Hi R Power! :smile:
R Power said:
hi
Because of conservation of mass (and incompressibility, ie constant density, of water) …
in steady flow, so long as the water fills the whole width of the pipe, the rate at which water enters one end of the pipe must equal the rate at which it leaves the other end. :wink:
It will not flow as fast as a stone dropped over the same vertical distance.
Mass flow rate will even remain same if velocity of water increases (due to gravity) and correspondingly cross sectional area of water within the pipe decreases.
R Power said:
hi
Can you give a physical example of such a flow?
i already gave example - in waterfalls from mountains. You can also it yourself. Put water in a glass then empty the glass slowly(so that you can observe) by tilting it and see as water reaches more and more near ground it's cross section decreases and velocity increases due to gravity.
My question is why such thing does not happen in vertical pipes
why?
and "why"
You are suggesting that the water should leave the sides of the pipe as it falls and form a column inside? That would involve the formation of a space between liquid and pipe. This would constitute a low pressure region which will support the water below it in the pipe, delaying the fall. The water inside is not, in fact, in free fall, but affected by the pressure situation of the whole column (which communicates throughout at the speed of sound in the water).
Your model of a waterfall seems right but the situation in a rigid pipe is very different. Perhaps you'd see the effect in a pipe constructed so it could not actually stretch but could alter its diameter. That would be a good design task!
  • · Replies 28 ·
  • · Replies 35 ·
  • · Replies 18 ·
