The generalization of Newton's 2nd Law to apply to variable mass systems
The discussion revolves around the generalization of Newton's second law to variable mass systems, focusing on the mathematical expression of momentum and its derivatives. Participants explore the implications of mass variability in the context of classical and relativistic physics.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants question the application of the product rule in differentiating momentum, with some expressing confusion about the validity of Newton's second law for variable mass systems. Others discuss the implications of special relativity on the understanding of mass and force.
The discussion is active, with participants providing insights into the mathematical derivation of momentum and its relevance to Newton's second law. There are differing views on the applicability of the law in variable mass scenarios, and some participants are exploring the relationship between classical mechanics and special relativity.
Some participants express uncertainty regarding their understanding of special relativity and its implications for Newton's laws, indicating a potential gap in knowledge that may affect their interpretations.
sedaw
F = dp/dt = d(mv)/dt = m(dv/dt) + v(dm/dt) = a + v(dm/dt)
i don't understand why d(mv)/dt = m(dv/dt) + v(dm/dt)
can someone help ?
TNX !:smile:
How do you calculate the derivative of a product?
ehild
This is simply obtained by using the product rule.
dp/dt = d/dt (mv) = m(dv/dt) + v(dm/dt) (using product rule).
I thought that Newton's second law was true only for systems with constant mass.
Well, written in the form of
[tex]F=m \frac{dv}{dt}[/tex]
it is valid inly for constant mass system since you assume that the mass is constant :P.
But assuming, that mass is dependent on velocity, which is true (according to SR) you get what sedaw wrote.
Thus, the best, most general form of Newton's 2nd law is
[tex]F=\frac{dp}{dt}[/tex]
as it doesn't imply anything being constant ;P
I know that [tex]\bold{F}=\frac{d\bold{p}}{dt}[/tex] is Newton's second law, but I read that this was true only with constant masses. Also, I don't know much about special relativity (I just finished my freshman year) but I thought it proved that Galilean transformation was flawed. Since Newton's laws are based on Galilean relativity, I don't think SR can show that N2 holds even for variable masses. Can it?
Well, what you read was wrong. In nonrelativistic physics, [itex]\mathbf{F} = \mathrm{d}\mathbf{p}/\mathrm{d}t[/itex] is valid regardless of whether mass changes.
If I remember correctly, in special relativity, Newton's second law (in the above form) is used to define the relativistic generalization of force. So that equation holds true in all cases. (Caveat: there are actually a couple of ways to define the relativistic generalization of force that are not quite compatible with each other... it turns out that force is not as useful a concept in special relativity as it is in non-relativistic, Newtonian physics.)
  • · Replies 27 ·
  • · Replies 42 ·
  • · Replies 0 ·
