| Thread Closed |
Wavefront Simulation using Geometry Optics and Physical Optics |
Share Thread | Thread Tools |
| May24-10, 11:17 PM | #1 |
I am required to simulate the propagation of a the wavefront produced by a laser light (about 633 nm) passing through a system of lens and undergoes a few reflection. What I did at the moment is to do ray tracing, record the optical path length of each ray, then connect every point of the same phase to approximate the wavefront. (The light ray will travel about 1 m)
Clearly, this would introduce some inaccuracy as there are phenomenon like diffraction and etc. I think it will be more accurate to simulate this using physical optics basis, but how good would the improvement be? More importantly, there are quite some irregular boundaries involve here (lens, for example), which would make the whole computation much more complicated. 1) How can i know the order of discrepancy between geometry optics approximation and physical optics? My application would require error of not more than micrometer range. 2) What are the governing equations should i plan to do the simulation using physical optics? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| May25-10, 12:07 AM | #2 |
If the lens is smaller than 0.00633 milimeters then you will have significant diffraction effects and you should use PO or GTD.
I suspect your lenses are much much larger so you should use GO. A PO integral of 633nm light going through even a small lens would require a lot of computer time. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Wavefront Simulation using Geometry Optics and Physical Optics
| How does Wavefront technology used in optics work? | Classical Physics | 2 | ||
| Book about physical optics | Science Textbook Discussion | 0 | ||
| physical optics... | Introductory Physics Homework | 4 | ||
| physical optics | Introductory Physics Homework | 1 | ||
| Physical Optics | Introductory Physics Homework | 1 | ||
