Calculating required pump pressure to maintain flowrate in a uniform horizontal pipe
The discussion focuses on calculating the required pump pressure for a horizontal water pipe that is 3 kilometers long, with a flow rate of 600 kg/s and an average velocity of 5.6 m/s. The friction loss coefficient is given as 0.002 per meter. The initial calculation using the formula pressure = (flowrate x G) / cross-sectional area yields a pressure of 54935.92 Pa at the end of the pipe. However, to determine the pump pressure accounting for frictional losses, the Darcy friction factor is utilized, leading to a pressure drop of approximately 80 Pa.
  • Understanding of Bernoulli's equation
  • Knowledge of Darcy friction factor in fluid mechanics
  • Familiarity with pressure calculations in fluid systems
  • Basic principles of turbulent flow and Reynolds number
  • Study the application of Darcy-Weisbach equation for pressure loss in pipes
  • Learn about the calculation of Reynolds number and its implications in fluid dynamics
  • Explore advanced concepts in fluid mechanics, focusing on turbulent flow behavior
  • Investigate pump selection criteria based on flow rate and pressure requirements
Engineers, fluid mechanics students, and professionals involved in hydraulic system design and analysis will benefit from this discussion, particularly those focused on pump selection and pressure calculations in piping systems.
Dave-RR
I am having trouble with calculating the required pump pressure in a horizontal water pipe, 3Km long. i know that the flowrate is 600Kg/s, average velocity 5.6m/s, cross-sectional area of pipe is 0.107143m^2 and losses due to friction average 0.002 per meter
pressure=force/area
bernoulli's equation
pressure = (flowrate x G)/cross-sectional area
= (600 x 9.81) / 0.107143 = 54935.92 Pa
i think that this is the pressure at the end of the pipe however i am unsure how to caculate the pump pressure given the frictional loss coefficient. i have had very little teaching in fluid mechanics but have researched Bernoulli's equation however i cannot see how it, is applicable to this problem is there any other equations i could use given the known elements
Reynolds number is about
[tex]\frac{U D}{\nu} = 1.7 \times 10^6[/tex]
This is clearly turbulent and not potential. Bernoulli's equation is not applicable here.
The solution is based on the exact statement, that for a steady flow in pipes mean pressure gradient is balanced by the shear at the wall. IF you work it out in spherical coordinates and by "friction" you mean Darcy friction factor, then
[tex] \Delta P = f \rho U^2 L / D /8 = 0.002 * 5.6^2 * 3000 / 0.3 / 8 \approx 80 \, Pa[/tex]
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 20 ·
12K
