Prove Dual Space Isometry: X = C[0,1] Sup Norm
The discussion revolves around proving properties of the dual space of the Banach space X = C[0,1] equipped with the supremum norm. The original poster defines a linear functional based on an element g from X and seeks to establish its continuity and calculate its norm.
  • Participants explore the linearity and continuity of the defined functional, with attempts to apply the supremum norm and integral properties. Questions arise regarding the correctness of the proofs presented and the method for calculating the norm of the functional.
Some participants express confidence in the correctness of the proofs regarding linearity and continuity. There is a suggestion to use the triangle inequality to establish an upper bound for the norm, and a participant proposes a potential method for finding the exact value of the norm.
Participants note the need to consider the supremum norm and the implications of the continuity of the functional in the context of the dual space. There is mention of a related question from another forum, indicating that this topic has been discussed previously.
complexnumber
For the Banach space [tex]X = C[0,1][/tex] with the supremum norm, fix
an element [tex]g \in X[/tex] and define a map [tex]\varphi_g : X \to \mathbb{C}[/tex]
by
[tex] \begin{align*}<br /> \varphi_g(h) := \int^1_0 g(t) h(t) dt, \qquad h \in X<br /> \end{align*}[/tex]
Define [tex]W := \{ \varphi_g | g \in X \}[/tex].
Prove that [tex]\varphi_g \in X^*[/tex] and calculate
[tex]||\varphi_g||_{X^*}[/tex].
The supremum norm for a function [tex]f \in C[0,1][/tex] is [tex]\displaystyle<br /> ||f|| = \sup_{x \in [0,1]} |f(x)|[/tex].
For [tex]h_1,h_2 \in X[/tex] and [tex]\lambda \in \mathbb{C}[/tex]
[tex] \begin{align*}<br /> \varphi_g(h_1 + h_2) =& \int^1_0 g(t) (h_1(t) + h_2(t)) dt =<br /> \int^1_0 g(t) h_1(t) dt + \int^1_0 g(t) h_2(t) dt = \varphi_g(h_1) +<br /> \varphi_g(h_2) \\<br /> \varphi_g(\lambda h_1) =& \int^1_0 \lambda g(t) h_1(t) dt = \lambda<br /> \int^1_0 g(t) h_1(t) dt<br /> \end{align*}[/tex]
So [tex]\varphi_g[/tex] is linear functional.
For any [tex]h \in X[/tex], [tex]\varphi_g[/tex] is continuous if [tex]\forall \varepsilon<br /> > 0[/tex] [tex]\exists \delta > 0[/tex] such that any [tex]h' \in X[/tex] satisfies
[tex] \begin{align*}<br /> d(h,h') < \delta \implies d(\varphi_g(h), \varphi_g(h')) <<br /> \varepsilon \text{.}<br /> \end{align*}[/tex]
The distance function is [tex]\displaystyle d(h,h') = ||h - h'|| =<br /> \sup_{x \in [0,1]} |h(t) - h'(t)|[/tex].
[tex] \begin{align*}<br /> d(\varphi_g(h), \varphi_g(h')) =& |\int^1_0 g(t) h(t) dt -<br /> \int^1_0 g(t) h'(t) dt | = |\int^1_0 g(t) h(t) - g(t) h'(t) dt | \\<br /> =& |\int^1_0 g(t) (h(t) - h'(t)) dt| \leq \int^1_0 |g(t) (h(t) - h'(t))| dt \\<br /> \leq & \int^1_0 |g(t)| |(h(t) - h'(t))| dt \leq \sup_{t \in<br /> [0,1]} |(h(t) - h'(t))| \int^1_0 |g(t)| dt \\<br /> =& d(h,h') \int^1_0 |g(t)| dt<br /> \end{align*}[/tex]
For any [tex]\varepsilon > 0[/tex], we get [tex]\displaystyle d(h,h') \int^1_0<br /> |g(t)| dt < \varepsilon[/tex] when [tex]\displaystyle d(h,h') <<br /> \frac{\varepsilon}{\displaystyle \int^1_0 |g(t)| dt} = \delta[/tex].
Thus [tex]\varphi_g[/tex] is continuous. Are the above proofs correct?
The formula for [tex]||\varphi_g||_{X^*}[/tex] is
[tex] \begin{align*}<br /> ||\varphi_g||_{X^*} :=& \sup \{ |\varphi_g(h)| | \norm{h} = 1<br /> \} \\<br /> =& \sup \left\{ |\int^1_0 g(t)h(t) dt| \bigg| \sup_{t \in [0,1]}<br /> |h| = 1 \right\}<br /> \end{align*}[/tex]
How can I find the value of this?
For the supremum, maybe some sort of triangle inequality application can give you a starting upper bound
As far as I can say, they are.
You have
[tex]\left|\int^1_0 g(t)h(t) dt\right| \le \int^1_0 |g(t)| |h(t)| dt \le \int^1_0 |g(t)| dt[/tex]
therefore
[tex]||\varphi_g|| \le \int^1_0 |g(t)| dt[/tex].
I think that [tex]||\varphi_g|| = \int^1_0 |g(t)| dt[/tex] holds. A naive approach to show this would be trying to approximate the step function [tex]h(t)=g(t)/|g(t)|[/tex] by continuous functions; but I guess there is a simpler solution.
BTW the same question was asked here: http://www.mathhelpforum.com/math-h...tial-geometry/146627-dual-space-isometry.html
Is this correct?
[PLAIN]http://9ya7ng.blu.livefilestore.com/y1pFP94kdkanTL7oWHQXuecgsG7MYfNfM3fHYVt7AE01cgDtbQY8VkjQk94V8H5WceDMp8kOlh-X1WSs79GZtIUTEWTFMCBtceU/q3.jpg
  • · Replies 43 ·
