Electric Potential, acceleration and velocity
The discussion revolves around a problem involving electric potential and the motion of charged spheres. The original poster describes a scenario with three small charged spheres arranged in a line, where they are released from rest, and they are trying to calculate the acceleration and final velocities of the spheres as they move apart.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to calculate the forces acting on the first sphere using the electric potential formula but encounters issues with large values and infinity in their calculations. They express confusion about how to approach the potential energy and kinetic energy relationship as the spheres move apart.
Participants have provided feedback on the original poster's approach, suggesting corrections to the force calculations and clarifying the relationship between potential and kinetic energy. There is an ongoing exploration of how to incorporate the interactions of all three spheres in the calculations, with some participants proposing that the total potential energy can be divided among the moving charges.
Participants note the importance of considering all interactions between the spheres and the implications of potential energy as the spheres move to infinity. There is also mention of unit checks and the need to account for all charge pairs in the potential energy calculations.
Brianjw
Having some trouble with an electric potential problem. I thought I understood it but I keep getting an infinity in the equation which just can't happen.
Three small spheres with charge 2.00 mC are arranged in a line, with sphere 2 in the middle. Adjacent spheres are initially 8.00 cm apart. The spheres have masses m1 = 20g, m2 = 85.0g and m3 = 20.0g, and their radii are much smaller than their separation. The three spheres are released from rest.
So from the last sentence I get the idea to treat it as 3 point charges.
For point charges potential = kq/r.
For the first question I need to find the acceleration on point 1.
My idea was to add up both forces applied to it by points 2 and 3. I used:
F = k*2.00mC/.08 + k*2.00mC/.16
F = ma so a = F/m But that gives me a = 168596338021 m/s^2 which doesn't work and seems rather large.
For the next 3 parts it wants me to find the velocity of each particle when they're far apart. The middle one is easy since its 0. The outter 2 will be equal but I can't seem to solve it without an infinity.
I know I will need to use K_1 + U_1 = K_2 + U_2.
I am not sure how to approach it since U = -QV, and V = the integral of k*q/r from r_0 to far away, aka infinity. Secondly, when U = -qV, what value to I use for Q and q??
Am I approaching this part wrong?
Thanks for the help.
At a quick glance
You seem to have used the equation for electric potential to calculate the force.
Also make sure you check your unit?
yea, shouldn't it be F1 = kq1q2/r1^2 + kq1q3/r2^2
Ya, thanks for pointing out my first problem, after making the correct change I got the right answer. Still don't see the way around the speed though, since its a point mass and its going off to infinity so I get a ln(infinity) in my answer in my equation of K_1 + U_1 = K_2 + U_2.
I see what you are doing wrong with your speed part.
You don't need to integrate anything: to find the energy you would integrate the force, but you already have the potential so there is no need to do that.
When the ball is released, its has only potential energy and its kinetic energy is zero. When it is very far away, r is so large that the potential energy is effectively zero. Therfore, you know how much kinetic energy it has when very far away. To find V at that point, don't just use the equation once; you have two other particles to consider.
Hope that helps
I got the idea but the one thing I can't solve for right now is the other moving charge. How do I incorporate that into the Potential equation? If it was fixed I would have it, but since the radius of the 3rd charge is changing with the radius of the 1st charge I can't seem to find the right answer.
Well, in the beginning there is so much potential energy. In the end, all of that is kenetic energy. It is reasonable to assume that both balls released end up at the same velocity. If you find the total potential energy at the begining, is it reasonable to find that each ball ends up with half of that in kenetic energy?
Ya I realized my error, when doing the potential I only did 2 of the 3 possible pairs. Once I realized that it fell together. Thanks for all your help!
If I helped even a little, I'm thrilled! :approve: :biggrin:
Goodluck with E&M
  • · Replies 22 ·
