Snell's law through three layers?
  • Thread starter Thread starter MCATPhys
    Law Snell's law
The discussion focuses on applying Snell's Law to determine the thickness of a gallium phosphide layer frozen in ice. The optical densities are specified as 3.5 for gallium phosphide and 1.31 for ice. The light beam enters at a 25-degree angle, resulting in a deviation of 12.25 mm from the expected path. The final calculated thickness of the gallium phosphide layer is approximately 42.2 mm, as confirmed by the book, despite initial calculations suggesting otherwise.
  • Understanding of Snell's Law and its application in optics
  • Knowledge of optical density and its significance in light refraction
  • Familiarity with trigonometric functions, particularly tangent and sine
  • Basic concepts of light behavior at material boundaries
  • Study the derivation and applications of Snell's Law in multi-layer systems
  • Explore optical properties of materials, focusing on gallium phosphide and ice
  • Learn about the implications of optical density on light propagation
  • Investigate practical examples of light refraction in layered media
Students and educators in physics, particularly those studying optics and light behavior in different materials, as well as professionals in materials science and engineering.
MCATPhys
A piece of gallium phosphide is frozen in ice. a beam of light is directed downward through the ice-gallium phosphide boundary at a 25 degree angle from the normal. The light emerges from the gallium phosphide 12.25 mm away from where it would have had the solid been pure ice. Find the thickness of the gallium phosphide layer. Gallium phosphide has the highest known optical density (3.5), and ice has the third lowest (1.31).
I know this question is supposed to be easy in that we need to apply snell's law. but can someone please draw an image of what it looks like... because i have no idea what they are asking... is the ice layer on top of the gallium layer...
Hi MCATPhys! :wink:
It's the same as if the question asked about a piece of gallium phosphide in air, with light hitting it at 25º …
but instead of air, there's ice. :smile:
tiny-tim said:
Hi MCATPhys! :wink:
So...
(1.31)sin25 = 3.5sinx
x = 9.10 degrees
then... tan9.10 = 12.25/height
height = 76.5 mm
Is that right? But the book says the answer is 42.2 mm.
ah … but 12.25 isn't the distance from the normal, it's the distance from the 25º line. :wink:
I really don't get it... :((((
If the gallium phosphide wasn't there (so the light was going through pure ice), then the light would continue at 25º.
The question says that the light is 12.25 mm away from that line.
but how do i calculate the distance from the normal the ray of light travels in ice. I'm guessing I subtract that number from 12.55 to get the actual distance.
btw.. thanks so much for helping me
If the thickness is d, then the light would have traveled dtan25º from the normal. :wink:
(btw, is it 12.25 or 12.55?)
okay... that means the light in the phosphide traveled dtan25 + 12.25...
so...
tan9.10 = (dtan25 + 12.25)/d
d = -40.0 mm
I suppose that's close enough to the right answer. I checked the question in the book again.. and it says 12.25 - does that sound wrong?
Hi MCATPhys! :smile:
(just got up :zzz: …)
MCATPhys said:
… I checked the question in the book again.. and it says 12.25 - does that sound wrong?
No, I only asked because you wrote 12.55 in your post #6. :wink:
31K
9K
