How Does a pH Meter Work and What Role Does the Reference Electrode Play?
  • Thread starter Thread starter Mizuki168
    Ph Work
The discussion revolves around the functioning of a pH meter, focusing on the roles of its electrodes, particularly the reference electrode. Participants explore the principles behind how pH meters operate, including the mechanisms of the electrodes and their interactions with solutions.
  • One participant describes the pH meter as having two electrodes: a pH electrode and a reference electrode, comparing its function to that of a thermocouple thermometer.
  • There is a claim that the pH electrode is a glass electrode with a membrane that allows hydrogen ions to enter, creating an electric potential difference that is measured by a voltmeter.
  • Participants express confusion about the reference electrode's role, noting that it is said to provide a stable electric potential but seeking clarification on how this is achieved.
  • Another participant explains that the reference electrode is typically made of Ag/AgCl and is submerged in a solution of known chloride concentration, which maintains a constant potential as long as the chloride concentration remains stable.
  • There is a question raised about why the reference electrode must be dipped in the solution being tested, leading to a discussion about the necessity of closing the circuit for measuring relative potential.
Participants do not reach a consensus on the understanding of the reference electrode's function, with some expressing confusion and others providing explanations that do not fully resolve the questions raised.
The discussion highlights uncertainties regarding the mechanisms of the reference electrode and its interaction with the testing solution, as well as the assumptions about the stability of the chloride concentration.
Mizuki168
Hey guys, so I have a project on the pH meter. Basically on what it is, what it's used for, how it works, and what principles does it run on. It is a group project but we can't seem to figure out some points and we've become very confused!
Mainly, it's how it works. We researched and understood that the pH meter has electrodes and it kind of works like a thermacouple thermometer. There are 2 electrodes (a pH electrode and a reference electrode). The pH electrode, according to us, is a glass electrode that has a membrane made out of some metal. When the glass electrode is put in the tested solution to determine the pH level, the hydrogen ions go in the glass electrode and then in turn some metal ions from the membrane go into the solution? And then there is a electric potential difference that is sent to the voltmeter that helps convert it into pH units.
But out real problem is, is what use is the reference electrode. We've done a lot of research on it and everywhere just says that it's to provide a stable electric potential. But how? And why?
www.ph-meter.info[/url] and specifically [url=http://www.ph-meter.info/pH-electrode-construction]www.ph-meter.info/pH-electrode-construction[/URL] contain most of the information you need.
Reference electrode is usually Ag/AgCl electrode, not different from those routinely used as a reference in many electrochemical experiments.
Reference electrode is usually Ag/AgCl electrode, not different from those routinely used as a reference in many electrochemical experiments.[/QUOTE]
Thank you for the websites however even after reading them I'm not quite understanding anything about the reference electrode...
I am not sure what the problem is. Such an electrode is made of Ag wire covered with AgCl, submerged in solution of chlorides of known concentration (usually either 1M or saturated KCl). Its potential is constant because that's the way electrodes work - this particular electrode has potential depending on the concentration of chlorides, as long as this concentration is constant, potential is constant as well.
Oke...so the chloride stays in the reference electrode. Then why must it be dipped in the solution being tested for pH level?
Not sure what your question is. Why whole electrode must be dipped? You can't measure concentration remotely. Why reference electrode must be dipped? You have to close circuit, you are measuring relative potential.
