How Do You Calculate Cooking Intensity from Cooling in an Oven Cycle?
  • Context: Graduate
  • Thread starter Thread starter Bacat
    Cooking Intensity
The discussion revolves around calculating the "cooking intensity" of food during an oven cycle, which includes phases of heating, holding, and cooling. Participants explore the integration of temperature changes over time to quantify cooking intensity, with a focus on the cooling phase described by Newton's Cooling Law.
  • One participant outlines the phases of the oven cycle, detailing the heating rate, holding temperature, and cooling process, and expresses a need to integrate the cooling function to calculate cooking intensity.
  • Another participant questions the relevance of the approach, suggesting that the focus should be on the interaction between the oven and the food rather than just the temperature profile of the oven.
  • A participant proposes using numerical integration methods, such as Excel, instead of calculus for the calculations, indicating a preference for practical solutions over theoretical ones.
  • There is uncertainty about the correct method to integrate the cooling function, with one participant asking whether a derivative is needed before integration.
Participants express differing views on the relevance of the calculations to the concept of cooking intensity, with some focusing on the mathematical integration and others questioning the approach's validity. The discussion remains unresolved regarding the best method to calculate cooking intensity.
Limitations include potential assumptions about the heat transfer between the oven and the food, as well as the simplifications made in the cooling model. The discussion does not resolve how these factors may affect the calculations.
Bacat
I have a block of food in an oven and I want to calculate the "cooking intensity" of the block during a controlled oven cycle. The cycle of the oven is that it heats at 5 degrees (C) per minute, holds the temperature at 300C for 1 hour, and then shuts off the oven to cool to room temperature. I define as "cooking" any temperature higher than 23C (room temperature). I use P for cooking intensity.
I am doing fine on the ramp-up and the hold. And I can use the heat equation to find the temperature of cooling at any time. But how do I integrate the total heat from the cooling function? I seem to be stuck on this point. Here's my work so far:
Ramping Up
For a constant heating rate r, this is just finding the area of a triangle. In this case, r = 5.
[tex]P=\int_0^t{rxdx}[/tex]
Holding
In this case, T = 300.
[tex]P=\int_0^t{TdT}[/tex]
Cooling
Newton's Cooling Law (using k to temporarily ignore A, m, c, and R):
[tex]T(t) = T_a + (T_0 - T_a)*e^{-kt}[/tex]
In this case:
[tex]T_a = 23[/tex]
Let [tex]k = 0.0035[/tex]
I want to find P from T(t). Can I just integrate like this?
[tex]P = \int_0^t{T(t)dT}[/tex]
Don't I need to take the derivative of T(t) first and add that under the integral?
And before anyone asks: no, this isn't homework. Really.
Science news on Phys.org
Should I ask the question in a different way? Or did Memorial Day just derail the forum? :)
Please help if you know the answer.
The concept here seems pretty odd to me because you're just calculating a temperature profile of the oven and not considering the heating of the food, so this doesn't have a whole lot to do with "cooking". The reality is that you always have a Newton's Law of cooling/heating scenario going on inside the oven between the oven and the food.
Anyway, being an engineer, I'd integrate numerically with Excel, so I can't help you do it with calculus...
