Time required to form a black hole
The discussion centers around the formation of black holes and the implications of time dilation during the collapse of a star. Participants explore the relationship between the perception of time for external observers versus those falling into the black hole, as well as the nature of event horizons and singularities.
  • Some participants question how a black hole can form in finite time, suggesting that as a star collapses, time slows down, leading to the idea that it should take an infinite amount of time to shrink below its Schwarzschild radius.
  • Others argue that while time appears to slow down for external observers, a clock on the collapsing star continues to tick normally, raising questions about the perception of time across the event horizon.
  • One participant notes that the formation of an event horizon can occur quickly as measured by external observers, and that a singularity may not be necessary for this process.
  • Another viewpoint suggests that an outside observer would never see an object fall through the event horizon, leading to the assertion that black holes cannot form as they would take an infinite amount of time to do so.
  • Some participants challenge the notion of infinities in the context of black holes, arguing that while they may exist mathematically, they do not correspond to physical reality.
  • A later reply emphasizes that the infinite time for a black hole to form is only from the perspective of an outside observer, and that the process still occurs despite being unobservable.
Participants express a range of views on the nature of time during black hole formation, with no consensus reached. There are competing interpretations regarding the implications of time dilation and the existence of singularities.
Participants highlight limitations in understanding the internal dynamics of black holes and the event horizon, noting that observations cannot be made from within the event horizon, which complicates the discussion.
DrZoidberg
How is it possible for a black hole to form within a finite time?
When a star collapses - the more dense it becomes and the closer it gets to becoming a black hole the more time slows down.
Shouldn't it take an infinite amount of time for it to become smaller then it's own schwarzschild radius?
Astronomy news on Phys.org
You've forgotten the lesson of Special Relativity -- there is no absolute rate of time. A clock* ticks one second per second, no faster, no slower.
A clock sitting on a collapsing star keeps ticking, always at a rate of one second per second. But once it crosses an event horizon, how long before the light from its face reaches an external observer?
*: When functioning properly, of course.
All the clocks (or time) when forming a black hole of inside a black hole slows down for an observer who is outside the black hole, but not for an observer inside the black hole. ie.,clocks are running correctly in the black hole but it seems that they are slowing down for an observer outside. So black hole has no objection in forming.
The process of time inside an event horizon is debatable. Formation of an event horizon in a collapse event is, however, possible in a very short period of time as measured by external observers' clocks. A singularity is not required to create an event horizon. It is unclear if a true singularity ever actually forms based on external observers' clocks. The event horizon tells us nothing about the state of matter inside, aside from being sufficiently dense to form an event horizon.
You are absolutely right. A black hole can would take an infinite amount of time as measured by the clock of an outside observer to fall through its own emerging event horizon and thus can never form. It is hardly surprising that the physics does not make sense inside a black hole. These things are physical impossibilities.
To ilustrate the point better, consider two astronoughts falling into a black hole. Let's call them A and B. A is let's say a mile ahead of B.
B would never see A fall through the event hoison. He would simply hover there for ever.
But how can B see himself fall through the event horizon if A who is in front of him takes an infinite amount of time to fall through? B does not even have to be there. It makes no difference.
Infinities do not exist in the real world. Even Einstein did not believe in the existence of these things!
There are a few things you've said that are not precisely correct. Infinities do in fact, exist, such as "0". The universe could be infinite, and we might not know. You're making some very seeping generalizations without sources. Einstein, like those of his time believed that black holes were a function of the math of GR, but then, they didn't have the observational data we do now.
As a general note to the OP, the infinite time for a black hole to form is only for an outside observer. Just because you don't see it happen, it still happens.
This is a reason for why we don't know what's going on past an event horizon. We can't see inside it in the first place. It's like trying to say "here's a completely sealed box, you can't see inside it, now tell me what I keep in here." For this you'd just go by what you expect to be in there by logic, but you still can never know for sure what is actually in there.
I'm no expert of course, so I'll rely on someone to correct me if I've said anything wrong. (:
  • · Replies 17 ·
  • · Replies 16 ·
