BLDC Motor - Operation with Phase Loss
The discussion centers around the operation of a three-phase BLDC motor when one of its phases fails. Participants explore whether it is feasible to run the motor using only the remaining two phases, considering the implications for performance and operation.
  • One participant inquires if a three-phase BLDC motor can operate with only two phases when one phase is disabled, suggesting that the software should stop firing the failed phase.
  • Another participant discusses the effects of phase loss, noting that unbalances can lead to increased motor temperature and negative sequence currents, which may complicate operation.
  • A participant agrees with the inquiry about running the motor with two phases and describes a specific commutation pattern involving six MOSFETs, questioning if the motor can run with only two phases after one phase is lost.
  • Another participant asserts that starting a three-phase induction motor from a stop position with only two phases is impossible due to the lack of starting torque, but acknowledges that running the motor after a phase loss is possible for a limited time.
Participants express differing views on the feasibility of operating a three-phase motor with only two phases. While some suggest it may be possible under certain conditions, others highlight significant challenges and limitations, indicating that the discussion remains unresolved.
Participants mention various factors affecting motor performance, such as electromagnetic torque and temperature increases due to phase loss, but do not reach a consensus on the practical implications of running the motor with two phases.
mramakrishnan
Hi,
I am using a 3 phase BLDC Motor. The scenario is,
"When anyone of the phases to the BLDC motor fails, the hardware will disable the particular phase. My software should stop firing that phase."
Thereby the motor should run with only 2 phases. Is this practically possible to run a 3 phase motor by just exciting the 2 phases of the motor when the 3rd phase has failed.
The most common cause of unbalance for three-phase motors is the loss of phase resulting from an open fuse, connector, or conductor. Unbalances in other connected loads can also affect the motor. A voltage unbalance of 3.5 % can produce a 25 % or greater increase in motor temperature. This results primarily from negative sequence produced by the unbalance. This current produces flux in the motor air gap rotating in the opposite direct ion to the actual motor direction. The relative effect is essentially double-frequency current in the rotor. Skin effect results in higher resistance, negative-sequence impedance remains essentially at locked-rotor value. Thus, high current and high resistance compounds the heating effect.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
I agree with you for your statement. What i want to know is that, when one of the phases connected to the motor becomes Open, is it practically possible to run the motor with the other 2 phases alone.
I am having 6Mosfets which is switched ON and OFF to run the fire the 3 phases to the motor. The pattern would be something like this,
3 Mosfets at the top and botton for the 3 phases,
1. ATOP - BBOT
2. ATOP - CBOT
3. BTOP - CBOT
4. BTOP - ABOT
5. CTOP - ABOT
6. CTOP - BBOT, then back to 1.
This is how commutation is performed in the system. Suppose if Phase A is lost, i will stop the commutation pattern involving the phase A. i.e
I will have to commutate only 2 mosfets,
1. BTOP - CBOT
2. CTOP - BBOT.
In this case, whether the motor will run with firing these two phases alone. Reduced performance of the system is acceptable.
Starting of three phase induction motor with two phases from zero speed (stop position) is impossible, because average of electromagnetic starting torque in this case is zero. Of course running continuity of motor after one phase loss is possible for short time.
  • · Replies 19 ·
