Is Spin Dependent Work Function a Significant Factor in Electron Emission?
The discussion centers on the relationship between spin-dependent work function and electron emission. It establishes that while the work function, defined as the energy required to remove an electron from the Fermi level, is generally considered spin-independent, there are nuances due to electron configuration. Specifically, spin-up electrons fill energy levels before spin-down electrons, leading to a slight spin dependency. However, this dependency is deemed insignificant as it is orders of magnitude smaller than the work function itself.
  • Understanding of work function in solid-state physics
  • Familiarity with Fermi-Dirac distribution
  • Knowledge of electron configuration and spin states
  • Basic concepts of valence band and energy levels
  • Research the implications of spin-dependent work functions in semiconductor physics
  • Explore the effects of magnetic fields on electron emission
  • Study advanced concepts in Fermi-Dirac statistics
  • Investigate the role of valence band width in electronic properties
Physicists, materials scientists, and researchers focusing on electron emission phenomena and spintronics will benefit from this discussion.
vanquynh05
Work function is the energy to remove 1 electron from Fermi level out of the system. From the about definition, it seems that work function ought to be spin-independent.
However in the electron configuration, the spin up is filled first and spin down is fill later. In result electron with spin down often stays in lower energy level comparing to one with spin up. So does that means work function should be spin-dependent?
The width of the valence band is significantly greater than the level-splitting, even in a large magnetic field, and it's also orders of magnitude smaller than the work function. To an extent, one has already taken spin into account as well, by using the Fermi-Dirac distribution.
In short, there's a dependence but it's not very significant as it's orders of magnitude smaller than the work function.
16K
