Constructive Proof of Material Implication
The forum discussion centers on the constructive proof of the material implication replacement rule, specifically the equivalence between (a => b) and (~a \/ b). It is established that a constructive proof using only intuitionistic rules is not possible for the implication (p → q) → (¬p ∨ q), as it is only classically valid. Conversely, the reverse implication (¬p ∨ q) → (p → q) can be proven using intuitionistic rules. Therefore, the proof of the first implication requires non-intuitionistic rules, such as the principle of explosion.
  • Understanding of natural deduction systems
  • Familiarity with intuitionistic logic
  • Knowledge of classical logic principles
  • Proficiency in propositional calculus
  • Study the principles of intuitionistic logic in depth
  • Learn about classical vs. intuitionistic proofs
  • Explore the principle of explosion in logic
  • Investigate the implications of material implication in propositional calculus
Logicians, mathematicians, philosophy students, and anyone interested in the foundations of logic and proof theory will benefit from this discussion.
Hugo Ferreira
Hi,
I'm struggling to find a constructive proof (through natural deduction) of the material implication replacement rule (i.e., that (a => b) <=> (~a \/ b). I believe the only possible way would be through contradiction, but I can't seem to get to it. Is it even possible?
Thx.
IF by "constructive proof" in a natural deduction system you mean a proof using only intuitionistic rules, then it's not possible: the implication
[tex]\left(p\rightarrow q\right)\rightarrow\left(\neg p \vee q\right)[/tex]
is not intuitionistically valid, whereas the reverse one:
[tex]\left(\neg p \vee q\right)\rightarrow\left(p\rightarrow q\right)[/tex]
is, so this one may be proved only with intuitionistic rules.
The first implication is only classically valid, so its proof must use a non-intuitionistic rule, like
[tex]\Phi,\neg\alpha\vdash\bot \Rightarrow \Phi\vdash\alpha[/tex]
  • · Replies 39 ·
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 16 ·
