A Heat Conduction Problem (Final exam on Monday)
The discussion revolves around finding the steady-state solution of the heat conduction equation under specified boundary conditions. The context includes multiple problems related to heat conduction, particularly focusing on the implications of boundary conditions on temperature distribution.
  • Participants explore the use of separation of variables and the implications of boundary conditions on the steady-state solution. There is a discussion about the nature of the steady-state temperature distribution and the assumptions regarding insulation and temperature at the boundaries.
Some participants have provided insights into the implications of the boundary conditions, particularly regarding insulated ends and the expected temperature distribution. There is an ongoing exploration of how these conditions affect the steady-state solution, with no explicit consensus reached on the final interpretation.
Participants note the importance of boundary conditions and initial assumptions, such as the insulation at one end and the temperature at the other end, which are critical to understanding the problem setup. There is also mention of the upcoming exam and the need to be prepared for various interpretations of the problems.
Jamin2112
I need to go into this test with great aplomb.
In each of Problems 1 through 8 find the steady-state solution of the heat conduction equation a2uxx=ut that satisfies the given boundary conditions.
1. u(0,t)=10, u(50,t)=40
3. ux(0,t)=0, u(L,t)=0
Will be using separation of variables; so assume u(x,t)=X(x)T(t)
After a long time---that is, as t approaches ∞---I anticipate that a steady state temperature distribution v(x) will be reached.
Then u(x,t) will just be a2v''(x)=v'(t). Since v is not a function of t, v'(t) = 0 and v''(x)=0.
v(x) must be a 1st degree polynomial: v(x) = Ax + B.
Notice that the initial conditions to problem one imply that
X(0)T(t)=10, X(50)T(t)=40.
I don't want T(t) to be something trivial, so
X(0)=10, X(50)=40
----> 10= 0 + B ---> B = 10
40=A*50 + 10 ----> A = (40-30) / 50 = 1/5
-----> v(x) = x/5 + 10
That's the steady state heat distribution, which is all the problem asked for.
Now problem 3. Notice the sub x.
Hmmmm... need to put the pieces of this puzzle together.
ux(0,t)=0 is saying that the rod is insulated at x=0.
So X'(0)=0.
The other initial condition says X(50)=40.
Where do I go from here?
Well, as you concluded above, you have v''(x) = 0. This gives:
v(x) = Ax + B
0 = X'(0) = v'(0) = A
so v(x) = B. Now v(L) = 0 = B so
v(x) = 0x + 0 = 0.
Doesn't that agree with your intuition if you insulate one end and hold the other at 0?
v(x) = Ax + B
v(x) = 0x + 0 = 0.
In other words, the temperature will be zero throughout the tube because only 0-degree air can come in?
If a question like this comes up on the final tomorrow, I'll just write: "Steady-state solution is zero because 0-degree air comes in one end"
It could be a solid metal rod insulated laterally and on one end with the other end in ice water. :smile:
Good luck on your exam. Just be ready to solve the problem completely if you are asked to do so. :cry:
