Can someone explain a DC electromagnetic generator in lamen terms for me?
The discussion revolves around the design and construction of a DC electromagnetic generator, particularly in the context of building a wind-powered generator. Participants explore various aspects of generator functionality, including coil turns, magnetic core arrangements, materials for construction, and the feasibility of achieving specific voltage and current outputs.
  • Homework-related
  • One participant describes a general layout for a generator involving a central magnetic core and conductive coils, seeking clarification on the arrangement of magnetic poles and the best materials for construction.
  • Another participant suggests that replicating existing designs may be more practical than building from scratch, recommending the use of a 12V automobile alternator instead.
  • Some participants discuss the factors affecting induced voltage, including rotor speed, magnetic flux, and the number of conductors, with one providing a formula for induced voltage.
  • A later reply questions the need for a constant 12V field to operate a car alternator, suggesting that a small battery could suffice for regulation.
  • Concerns are raised about the potential low output of homemade generators compared to commercial alternatives, emphasizing the importance of efficiency in design.
Participants express differing views on whether to build a generator from scratch or use an existing alternator. There is also uncertainty regarding the efficiency and practicality of homemade generators compared to commercial options.
Participants mention various assumptions about generator design, including the effects of coil turns on voltage output and the materials used for construction, without reaching a consensus on the best approach.
Individuals interested in DIY projects related to renewable energy, particularly those exploring the mechanics of electromagnetic generators and wind power applications.
waddlecaudle
I have been researching generators lately, whilst contemplating building my own wind powered generator. I think I understand the general layout: a central magnetic core that rotates with an outside ring of conductive coils spun in specific alternating turns with their own magnetic cores. If I am wrong please correct me, the best general description I could find for building one was:
http://www.otherpower.com/woodmill.html
I still have a few questions and appreciate any help that can be given.
I understand that the number of turns of the coil effects the voltage output. I was wondering if there is a simple way to calculate the number of turns of the wire without sitting down and manually trial/error testing turns. I found a few sites, but they gave me different explanations yielding different answers.
As far as the magnetic cores of the coils go, does it matter how the poles of these cores are arranged? Or does it just matter that it they be magnetic?
What is the best material to hold the actual rotating magnet with. In the website above they use wood, but this is just a simple homemade solution. Wouldn't some sort of light metallic core be better?
Would it take a relatively large generator to create ~20 amps at 12V? I know that engineers hate this kind of question, but as far as generators go am I looking at a smaller one that can be powered by wind, or am I looking at something that has to use a gas motor?
Obviously I am no engineer, but just a guy that likes to tinker with things. If something that I say sounds ridiculous please correct my ignorance. All help is greatly appreciated.
My advice - don't try to replicate a century of learning in building these devices - go find one already built. You can probably find a 12V automobile alternator at a junkyard for free that will do about what you are trying to do.
Well what's the fun in that silly :) I appreciate the thought and have considered it, but would rather enjoy building one. Think it would be fun. And I like learning how things work. I have my hands on one, but having one doesn't really answer my questions so I figured I would ask. Thank you
Induced voltage depends on speed of rotor, flux in machine, and number of current paths, length and number of conductors.
eind=(v x B) dot l ,(speed, flux density, length) vector quantities.
Make a sketch and do the math. A visit to the library wouldn't hurt either, many good books on the subject. As phyzguy pointed out, don't re-invent the wheel.
Without much study i believe the generator inn the link is a AC synchronous generator. Like the car alternator. Principle is the same, but you need a rectifier.
Wave a coil in front of a magnet and prove to yourself that magnetic induction works by looking at a meter. Take a cycle alternator apart, look at how it works and onserve the effect of speed changes and load changes. Then go out and find a cheap / free 12V car alternator. You probably don't have the knowledge or facilities to make anything that will do anything as well at that. That's if you actually want to use it for a serious application. You wouldn't want to waste all that effort in building the turbine bit and then produce just a few measly watts, would you? Even the commercial small wind turbines don't do much!
Correct me if I'm wrong, but wouldn't you need a constant 12v field to operate a regular car alternator, and doesn't this defeat the purpose of building a homemade neo-magnet alternator?
Yes. That's a point. You only need a small battery in the system, though. It also would mean you could regulate the output voltage.
  • · Replies 27 ·
  • · Replies 37 ·
  • · Replies 17 ·
  • · Replies 28 ·
18K
11K
