Reduction of benzophenone to diphenylethanol
  • Thread starter Thread starter Moogie
    Reduction
The reduction of benzophenone to diphenylethanol involves the use of 4 moles of sodium borohydride (NaBH4) as a reducing agent. During the reaction, NaBH4 donates hydride ions, resulting in an intermediate with a negatively charged oxygen species. The formation of diphenylethanol occurs only after an acid work-up step, where water is added and the mixture is boiled to release the alcohol. The balanced equation for this reaction can be represented as NaBH4 + 4 Benzophenone, leading to the formation of the intermediate complex before the final product is obtained.
  • Understanding of organic chemistry reaction mechanisms
  • Familiarity with sodium borohydride (NaBH4) as a reducing agent
  • Knowledge of carbonyl group reduction processes
  • Basic skills in writing and balancing chemical equations
  • Research the mechanism of sodium borohydride reduction of carbonyl compounds
  • Learn how to write and balance chemical equations for reduction reactions
  • Explore the acid work-up process in organic synthesis
  • Investigate alternative reducing agents for carbonyl reductions
Chemistry students, organic chemists, and professionals involved in synthetic organic chemistry who are interested in reduction reactions and alcohol synthesis.
Moogie
Hi
When you are reducing benzophenone to diphenylethanol you use 4 moles of sodium borohydride. I don't know how you would write this as an equation because I don't know what the sodium borohydride becomes. It has lost 4 hydride ions and is just with a sodium and boron. Also, you haven't made the alcohol at this stage yet either - you have an intermediate with an O- species in it. YOu don't form the alchol until the acid work up step
How would i write a balanced equation for this stage of the reaction?
e.g. NaBH4 + 4Benzonphenone etc
thanks
Are you sure it is diphenyl'ethanol', not diphenyl'methanol' ?
NaBH4 is used to reduce carbonyl group to alcohol, or in other words, it donates a hydride. The hydride bonds with the carbon, and oxygen gets a negative charge. Now, a new complex is formed. You can see the reaction here: http://www.chemguide.co.uk/organicprops/carbonyls/nabh4eq1.gif
In the second stage of the reaction, water is added and the mixture is boiled to release the alcohol from the complex.
http://www.chemguide.co.uk/organicprops/carbonyls/nabh4eq2.gif
Source: http://www.chemguide.co.uk/organicprops/carbonyls/reduction.html
Hope this helps :)
It was methanol - my mistake. Thanks for the link
25K
11K
