Register to reply
Work done on capacitors and more
Share this thread:
Tntgsh
#1
Jun9-10, 09:06 PM
P: 9
Hello, guys! Here I am again asking for your help...This is question number 2 from http://www.studyjapan.go.jp/en/toj/pdf/007.pdf
2) Consider the circuit shown in Fig. 5, consisting of a battery of voltage E, a switch S, and a parallel-plate capacitor with capacitance C. The capacitor consists of two parallel conducting plates of equal area A separated by a distance d. After the switch S is closed and the capacitor is fully charged, a conducting plate of thickness d/3 and area A is inserted slowly between the plates of the capacitor. The inserted conducting plate is kept parallel to the conducting plates of the capacitor. Select answers to the questions from (a) to (z) below, and write the symbol of the answer in the box.
(1) Find the capacitance of the capacitor after the conducting plate is inserted.
(2) How much is the increase in the charge stored in the capacitor caused by inserting the conducting plate?
(3) How much is the increase in the energy stored in the capacitor caused by inserting the conducting plate?
(4) How much work is done by the battery during the insertion of the conducting plate?
(5) How much work is done by the force applied to the conducting plate during its insertion?
Next, the switch S is opened, and the conducting plate is removed slowly. How much work is done by the force applied to the conducting plate to remove it?
2. Relevant equations
C=Q/V
U=qČ/2C
C=[tex]\epsilon[/tex]0A/d
3. The attempt at a solution
Actually, I haven't done much 'cause I don't know what to do. Any ideas?
Sorry about not posting anything at the "attempt" section, but I really don't know how to start...I tried, I swear! Actually, I tried a lot ><
Thanks for the help, guys!
Phys.Org News Partner Science news on Phys.org
New model helps explain how provisions promote or reduce wildlife disease
Stress can make hard-working mongooses less likely to help in the future
Grammatical habits in written English reveal linguistic features of non-native speakers' languages
bharath423
#2
Jun9-10, 09:42 PM
P: 30
when we insert a conductor in between due to field -ve charge comes on one side and +ve charge on the other and since its a conductor Electric field inside is zero so charge comes on to surface,so its just like two new capacitors with distance between palates is d/3 each..
potential drops as E/2,E/2 to each then u can find the charge on plates with new capacitance values for each.
so the we get the additional charge the battery should provide,so the work done by battery is additional charge*E...
to find work done by u find the change i potential nergy before and after placing conductor
Tntgsh
#3
Jun12-10, 01:21 PM
P: 9
Ohh, I got it!
(1) Initial capacitance: 0A/d
When we introduce the conductor, each of the "two capacitors" will have capacitance = 3[tex]\epsilon[/tex]0A/d. Since I can assume the "two capacitors" are arranged in series, Final capacitance = Capacitance/2. So, final capacitance will be 3[tex]\epsilon[/tex]0A/2d=3C/2.
(2)Initial charge = CE
Final charge = 3CE/2
Increase in charge = 3CE/2-CE=CE/2
(3)Initial energy = CEČ/2
Final energy = 3CEČ/4
Increase in energy = 3CEČ/4-CEČ/2=CEČ/4
(4)bharath423 said that the work done by the battery will be Additional charge*E=CEČ/2
(5)The work done by the force will be =-Increase in energy=-CEČ/4
(6)The work done by the force will be, once again, =-Increase in energy.
Energy now=3CEČ/4
But here's my doubt...when I remove the conductor, will the voltage E change?
Thanks a lot for the help! ^^
Register to reply
Related Discussions
Question on AC Capacitors used in place of DC Capacitors Electrical Engineering 3
Capacitors Introductory Physics Homework 1
Discharging Capacitors into Capacitors General Physics 21
What is the voltage across the capacitor plates Introductory Physics Homework 3
Capacitors charging capacitors... Introductory Physics Homework 9
