Integration of a rational function
The discussion revolves around the integration of a rational function, specifically the integral of the expression \(\int\frac{x^{2}-2x-1}{(x-1)^{2}(x^{2}+1)}dx\). Participants are exploring the partial fraction decomposition of the rational function involved.
  • Mixed
  • Participants discuss the breakdown of the rational function into partial fractions, with attempts to find coefficients A, B, C, and D. There are questions about the correctness of these coefficients and the method used to derive them. Some participants suggest using the Heaviside coverup method for finding coefficients more efficiently.
The conversation includes various attempts to verify the coefficients derived from the partial fraction decomposition. Some participants express uncertainty about their calculations, while others provide alternative methods for finding the coefficients. There is no explicit consensus on the correct approach or final values of the coefficients, but several productive suggestions have been made.
Participants mention the use of external tools like Wolfram Alpha, which is viewed with skepticism regarding its educational value. There are also references to imposed homework rules that discourage reliance on such tools, indicating a focus on understanding the underlying concepts rather than just obtaining answers.
stripes
find
[tex]\int\frac{x^{2}-2x-1}{(x-1)^{2}(x^{2}+1)}dx[/tex]
None
[tex]\frac{x^{2}-2x-1}{(x-1)^{2}(x^{2}+1)} = \frac{A}{x-1} + \frac{B}{(x-1)^{2}} + \frac{Cx + D}{x^{2}+1}[/tex]
[tex]x^{2}-2x-1 = A(x-1)(x^{2}+1) + B(x^{2}+1) + (Cx + D)(x-1)^{2}[/tex]
[tex]x^{2}-2x-1 = Ax^{3}-Ax^{2}+Ax-A+Bx^{2}+B+Cx^{3}-2Cx^{2}+Cx+Dx^{2}-2Dx+D[/tex]
[tex]x^{2}-2x-1 = x^{3}(A+B+C) + x^{2}(-A+B-2C+D) + x(A+C-2D) - A + B +D[/tex]
so A+B+C = 0, -A+B-2C+D = 1, A+C-2D=-2 and -A+B+D=-1
solving for coefficients, we get
A = 5/3
B = -2/3
C = -1
D = 4/3
so [tex]\frac{x^{2}-2x-1}{(x-1)^{2}(x^{2}+1)} = \frac{5/3}{x-1} - \frac{2/3}{(x-1)^{2}} - \frac{x-(4/3)}{x^{2}+1}[/tex]
but apparently, the last statement is not correct. Did I break down the rational function incorrectly?
Thank you all in advance for your help!
Check A+B+C=0.
i think that's ok? but -A+B-2C+D = (-5 -2 +6-4)/3 = -5/3?
so did I get all my coefficients messed up? Arghhh...
The Chaz said:
Cheating to the third power :biggrin:
1) Obviously the Prof. doesn't want students to use Wolfram alpha.
2) The "show steps" feature adds insult to injury. Just knowing the correct answer is going to give away nontrivial information to the student.
3) And Wolfram alpha is lying to you when it shows the steps. Not that there is anything wrong in these steps, but these are not the steps Wolfram alpha uses itself when it computed the answer. If you ask Wolfram alpha to show the steps, what it does is crank up the high school algorithm that gives the same answer, as it is most likely that this will yield the desired steps (I mean, who else other than students having difficulties with their assignments would want to see this?).
Wolfram alpha uses series expansion methods to compute the answer, which is way more efficient than the usual high school method. The general rule of thumb is that methods that involve solving equations for variables are less efficient compared to methods that don't involve solving equations.
Finding the constants is tedious and error-prone, but checking them is relatively simple, and you should do this. If you get a common denominator for what you have on the right, you should end up with what you have on the left. If you do, then you have the right constants.
I ended up finding the right constants, they were 1, -1, 1, and -1 I think. Did the question again and got it right!
And as for the Wolfram Alpha thing...I use it when I am completely stumped. It gives me hints and guides me in the right direction. And this "high school method" you speak of makes me sound like a high-schooler, which I am most definitely not lolll.
One technique I like to use when solving for the coefficients is the Heaviside coverup method. When you get to this point
Substitute a value for x to eliminate some terms. In this case, x=1 works. This leaves you with [itex]-2 = 2B[/itex], and you can immediately see that B=-1. Ideally, you can use different values to solve to isolate different coefficients quickly. Alas, that's not the case in this problem. If you plug in the value you found for B, you get
[tex]2x^{2}-2x = A(x-1)(x^{2}+1) + (Cx + D)(x-1)^{2}[/tex]
so you only have three equations and three unknowns to solve.
I see! Well, this is how I would do this problem. I would start by writing:
x^2 - 2 x - 1 = x^2 - 2 x + 1 - 2 = (x-1)^2 - 2
So, we have:
(x^2 - 2 x - 1)/[(x-1)^2 (x^2 + 1)] =
1/(x^2+1) - 2/[(x-1)^2 (x^2 + 1)]
Expanding the last term about the point x = 1 and keeping only the singular terms yields:
- 2/[(x-1)^2 (x^2 + 1)] = -2/(x-1)^2 [expansion of 1/(x^2+1) around x = 1]
Put x = 1 + t:
1/(x^2+1) = 1/[(1+t)^2 + 1] = 1/(2 + 2 t + t^2) =
1/2 1/[1+t+t^2/2] = 1/2 [1-t +t^2/2 + ...]
So, we have the expansion:
-1/(x-1)^2 + 1/(x-1) + nonsingular terms
If we now do the same at the singularities of 1/(x^2+1) and keep the singular terms, then the sum of all the singular terms from all the expansions, S(x), is the partial fraction expansion. This is because the difference between the rational function R(x) and S(x) will be a function that has no singularities, therefore it is a polynomial. But since both R(x) and S(x) tend to zero at infinity, we have that
R(x) = S(x).
So, we could now proceed to find the singular terms in the expansion around the singularities of 1/(x^2+1) at x = ±i. However, we can skip that as the partial fraction expansion is already determined by the above terms. This is because the large x behavior of
is -2/x^4, while the part of the partial fracton expansion we have so far is
So, clearly the partial fraction expansion due to the singular terms coming from 1/(x^2+1) must cancel the asymptotic 1/x and 1/x^2 behavior of the above two terms. We know that the the remaining terms of the partial fraction expansion will be of the form:
(A x + B)/(x^2 +1)
Expanding around x = infinity gives:
(A x + B) 1/x^2 1/(1+1/x^2) =
A/x + B/x^2 + O(1/x^3)
Expanding the two terms we got so far about infinity gives:
-1/(x-1)^2 + 1/(x-1) =
-1/x^2 + 1/x 1/(1 - 1/x) + O(1/x^3) =
-1/x^2 + 1/x + 1/x^2 + O(1/x^3) =
1/x + O(1/x^3)
So, A = -1 and B = 0 and we have:
(1-x)/(x^2+1) -1/(x-1)^2 + 1/(x-1)
count iblis, B ≠ 0, B = -1
Your B is my 1/(x-1)^2 coefficient.
I wonder what the grader would think if stripes were to turn in his homework using that solution.
It's not that different from the Heaviside coverup method you mentioned. If we have a rational function R(x) which has a linear factor in the denominator 1/(x-a)^n, then we can take that factor out and write:
R(x) = P(x) 1/(x-a)^n
So, we see that P(a) is the coefficient of 1/(x-a)^n (to do this "by the book", you would write out the equations as you did and then put x = a). To find the coeficient of 1/(x-a)^(n-1), using the Heaviside coverup method, one would subtract p(a)/(x-a)^n from R(x), simplify the rational function; you know that the numerator will contain a factor x-a that cancels against the denominator (you can use synthetic division to divide the numerator by x - a), so we can write:
R2(x) = R(x) - p(a)/(x-a)^n = P2(x)/(x-a)^(n-1)
And then we can repeat this by subtracting P2(a)/(x-a)^(n-1) from R2(x), simplify the rational function, divide numerator and denominator by x-a to obtain:
R3(x) = R2(x) - p2(a)/(x-a)^(n-1) = P3(x)/(x-a)^(n-2)
etc. etc.
But this whole process is equivalent to finding the first part of the Laurent expansion of R(x) around x = a, so you could just as well do that using any method that is most convenient, not necessarily using the above iterative process...
So, in the way you wrote it down the next step would be to factor the left hand side of the last equation
2x^2 - 2x = 2x(x-1)
and cancel (x-1) on both sides:
2x = A(x^2+1) + (Cx+D) (x-1)
  • · Replies 105 ·
13K
  • · Replies 18 ·
