Thread Closed
How does a generator produce AC current?
Share Thread Thread Tools
Jun12-10, 05:54 AM   #1
I just dont understand how it does, because I never noticed the terminals change positions.
I understood how DC generators work, but not AC.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jun12-10, 07:44 AM   #2
Mentor
Take a loop of wire connected to an ammeter, and spin it inside a magnetic field. Look at sign of the current.
Zz.
Jun12-10, 07:48 AM   #3
Recognitions:
Gold Membership Gold Member
In a dc generator, current is forced to flow in one direction; in an a/c generator is it allowed to flow in two. A/C power is widely used because it can be transmitted much more economically via step up power transformers...reducing current flow and reducing transmission wire size and power losses....
Remove the rectifiers (diodes) which prevent reverse current flow in a typical generator and you change a dc to an ac generator...
See here for a more complete discussion and diagram:
http://en.wikipedia.org/wiki/Alterna...e_of_operation
generators and alternators are slightly different...see the bottom of the WIKI page for further information.
There are different types of generators, see commutators to understand how current flow direction may be governed:
http://en.wikipedia.org/wiki/Commutator_(electric)
Jun12-10, 07:51 AM   #4
Quote by ZapperZ View Post
Zz.
I dont have the apparatus.
Quote by Naty1 View Post
So the coil changes directions? It starts moving in clockwise, and then changes to anticlockwise?
Im still so confused =/
Jun12-10, 08:46 AM   #5
Mentor
No, in an AC generator, the coil keeps on rotating in the same direction. As the coil rotates, the magnetic flux goes through the coil first in one direction, then the other, as "seen" from the point of view of the coil. The changes in the magnetic flux through the coil alternate in direction, therefore so does the induced current.
Jun12-10, 12:12 PM   #6
The simplest ac generator is a rotating permanent (dipole) magnet inside a stationary coil, sometimes called a dynamo. The only requirement is that the permanent magnet axis of rotation is perpendicular to the dipole field, and in the same plane as the stationary coil. If the permanent magnet were stationary, the ac output must be taken off the rotating armature via sliding contacts via brushes on "slip rings". The rotating dipole magnet actually produces an output voltage on the coil (by Faraday induction), and if a load resistance is connected, a current is produced.
Bob S
Jun12-10, 06:46 PM   #7
The basic principle involves 3 dimensions. If a magnetic field has a direction straight up from a table top and a straight wire is placed in a north south direction on the table top then moving the wire in a east west direction will cause a voltage to appear on the ends of the wire.
A good example of this can be found if you take apart an old hard disk drive. They have a coil of wire inside two very strong magnets. Be carefull handling them as they can pintch fingers and shatter.
Loud speakers are also an example of this. They consist of a coil of wire in a magnetic field. The coil moves when a current passes through it. If the cone is moved they will generate a voltage.
Another example is in a old mechanical meter movement. Again a coil of wire moves when a current is passed through it.
Jun12-10, 07:12 PM   #8
Quote by thedore View Post
Loud speakers are also an example of this. They consist of a coil of wire in a magnetic field. The coil moves when a current passes through it. If the cone is moved they will generate a voltage. .
Actually not. High quality loudspeakers have moving voice coils in a uniform magnetic field. In this case, a current in the coil moves the speaker cone, but moving the coil will not generate a voltage.
Bob S
Jun12-10, 08:07 PM   #9
He's correct, Bob. Moving the coil in the magnetic field will generate a potential across the coil.
Jun12-10, 08:11 PM   #10
Quote by jtbell View Post
Well, that opens up a can of worms. What transformation does the magnetic field undergo in a rotating reference frame?
Jun12-10, 09:41 PM   #11
Recognitions:
Quote by Cycloned View Post
Are you perhaps asking about the slip rings/commutator brushes?
Jun13-10, 12:28 PM   #12
Quote by Phrak View Post
Phrak-
Moving a coil in a uniform magnetic field does not produce a voltage, because the voltage induction process is based on the Faraday induction law in integral form:
V = -d/dt[N∫B·n dA] = -N·A·dB/dt = -N·A·(∂B/∂x)(dx/dt)
where A and N are the area and # of turns in the coil, and dx/dt is the coil displacement velocity. If B is a uniform field, then ∂B/∂x is zero, and the induced voltage V is zero. The loudspeaker works on the principle of the Lorentz vxB force, which does not involve the time derivative dB/dt.
Bob S
Jun14-10, 02:23 PM   #13
Quote by Bob S View Post
Phrak-
Bob S
Oh, right. The field is effectively uniform, and radial.
Thread Closed
Thread Tools
Similar Threads for: How does a generator produce AC current?
Thread Forum Replies
Current needed through solenoid to produce given B field Introductory Physics Homework 1
How does a loop of wire in a generator produce alternating current? Introductory Physics Homework 1
EASY Multiple concept questions- How does a loop of wire in a generator produce AC Introductory Physics Homework 0
Does a current produce an electric field? Introductory Physics Homework 15
At what rate must the current be to changed to produce 40V emf Introductory Physics Homework 3
