Integrating over a bounded surface
The problem involves finding the average value of z for a spherical surface of radius R that is situated above the x-y plane. The context is rooted in the geometry of spheres and integration over surfaces.
  • The original poster attempts to set up a double integral to calculate the average value of z, but encounters difficulties with the integration limits and the resulting values. Some participants question the formulation of the integral and suggest that it may not account for surface area weighting appropriately. Others propose using polar coordinates to simplify the integration process and clarify the area differential.
The discussion is ongoing, with participants exploring different methods for setting up the integrals. There is a suggestion to change to polar coordinates, and some participants are examining the implications of including the correct area differential in the calculations. No consensus has been reached yet, but there are productive directions being explored.
Participants are considering the implications of surface area in their calculations and the potential need to adjust the integral setup to reflect the geometry accurately. There is also mention of the integration limits and how they relate to the surface area of the hemisphere.
dimensionless
Find the average value of z for a the spherical surface of radius R that resides above the x-y plane.
Equation of a sphere
[tex]x^2+y^2+z^2 = R^2[/tex]
I rearrange the equation above and do a double integral
[tex]z_{total} = \int \int \sqrt{ R^2 - x^2-y^2} dx\, dy[/tex]
To get the aver value of z, I divide the whole thing by the surface area in the x-y plane that is bounded by the sphere.
[tex]z_{average} = \frac{1}{\pi R^2} \int \int \sqrt{ R^2 - x^2-y^2} dx\, dy[/tex]
I tried setting the integration limits for x to 0 and [tex]\sqrt{R^2-y^2}[/tex], and y to 0 and R(and I multiplied the whole thing by 4 since the integration is only being taken over a quarter of the surface).
[tex]z_{average} = \frac{4}{\pi R^2} \int_{0}^{R} \int_{0}^{\sqrt{R^2-y^2}} \sqrt{ R^2 - x^2-y^2} dx\, dy[/tex]
When I try to solve this, I get some crazy number with infinity in it. I'm not sure where I'm going wrong.
depending on how you want to average I'm not sure your integral it right form the get go...
I would think you would want to weight it by surface area, so the average should be somethng like:
[tex]\frac{\int z.dA}{\int dA}[/tex]
the integral you've written down is over circle, so doesn't give the same weighting, in this case dA is not equal to dxdy
either way changing to spherical coordinates will save you a lot of time...
Did you consider changing to "polar coordinates"?
Then your numerator becomes [tex]\int_{r= 0}^R\int_{\theta= 0}^{2\pi}\sqrt{R^2- r^2} rd\theta dr[/tex].
Your denominator is just the surface area of a hemi-sphere of radius R: [itex]2\pi R^2[/itex].
(Edit: I have added an "r" to the integral. The differential of area in polar coordinates is "[itex]r d\theta dr[/itex]", not "[itex]d\theta dr[/itex]"!)
[tex]\int_{r= 0}^R\int_{\theta= 0}^{2\pi}\sqrt{R^2- r^2}d\theta dr = \int_{r= 0}^R\int_{\theta= 0}^{2\pi}z(r)d\theta dr[/tex]
the point I'm making is if you perform that integral without the z(r), you do not get the correct surface area of the hemi-sphere
[tex]\int_{r= 0}^R\int_{\theta= 0}^{2\pi}d\theta dr \neq 2\pi R^2[/tex]
  • · Replies 19 ·
