Equation of tagent line to the graph
  • Thread starter Thread starter Tjvelcro
    Graph Line
The discussion revolves around finding the equations of tangent lines for given functions at specified points. The subject area includes calculus concepts related to derivatives and tangent lines.
  • Mixed
  • Participants explore how to use given points and slopes to formulate equations of tangent lines. Some express uncertainty about the relevance of derivatives and the steps necessary to find the tangent line equations.
Several participants have provided insights into the relationship between points on the curve, slopes of tangent lines, and the equations of those lines. There is an ongoing exploration of the connections between the derivative values and the slopes, with some guidance offered on interpreting the problem statements.
Participants question the clarity of the problem statements and the assumptions regarding the values of functions and their derivatives. There is also mention of potential confusion regarding the requirements of the problems, particularly in distinguishing between finding values and equations.
Tjvelcro
a. Find the equation of the tangent line to the graph of y=g(x) at x = 5 if g(5) = -3 and g'(5) = 4
b. If the tangent line to y = f(x) at (4,3) passes through the point (0,2), find f(4) and f'(4)
y=mx =b
f(a+h)-f(a)
h
y – y1 = m(x – x1)
So in a. I'm given a point (5, -3) but I'm not sure if we can find the equation right away or find the slope first. I also don't know what g'(5) = 4 has to do with the problem. Should I sketch them?
For b. I'm not even sure what I'm trying to find, a value? equation?
Tjvelcro said:
a. Find the equation of the tangent line to the graph of y=g(x) at x = 5 if g(x) = -3 and g'(5) = 4
Instead of g(x) = -3, you mean g(5) = 3. g(x) = -3 means that for any x, the y value is -3.
y=mx =b
f(a+h)-f(a)
h
y – y1 = m(x – x1)
You have a point -- (5, -3) -- that's on the curve and on the tangent line, and you have the derivative of g at 5 -- g'(5) -- that is the slope of the tangent line. Given a point on a line and its slope, what is the equation of the line?
For b, you are suppose to find two values, f(4) and f'(4). That's why it says "find f(4) and f'(4)."
You are apparently missing the connection between the value of the derivative at a point and the slope of the line that is tangent to the curve at that point.
For this problem you are given two points on the tangent line (hint: find the slope of this line) and the point of tangency -- (4, 3). Finding f(4) is really a no-brainer.
a. so I use y – y1 = m(x – x1)
sub in (5, -3) for the point and 4 for the slope?
Solve for y.
So y-(-3)=4(x-5)
y=4x-23
b. I would use m=(y2-y1)/(x2-x1) to find the slope as you suggest.
m=(3-2)/(4-0)
m=1/4
Now I need to find f(4) and f'(4)
I need to find the equation first as I did in part a.
sub in (4,3) for the point and 1/4 for the slope?
So y-(3)=1/4(x-4)
y=(1/4)x+2
Now I can solve for f(4) but is f'(4) any different?
y=(1/4)(4)+2
y=3
Solve for y.
So y-(-3)=4(x-5)
y=4x-23
Correct.
m=(3-2)/(4-0)
m=1/4
Correct.
Don't overthink these. (4, 3) is a point on the graph of f, so what is f(4)?
For f'(4) you are still missing the connection between the 1) slope of the tangent line to a function at a point (a, f(a)) on the graph and 2) the value of f'(a). For this problem, once you have found the slope of the tangent line (m = 1/4), you DON'T NEED TO DO ANY OTHER CALCULATIONS!
In particular, you ARE NOT ASKED to find the equation of the tangent line - just f(4) and f'(4).
So y-(3)=1/4(x-4)
y=(1/4)x+2
y=(1/4)(4)+2
y=3
So f(4)=3 as given in the question...
f'(4)=1/4 since 1/4 is the slope of the tangent line at point (4,3)?
Thanks for the help! Test this Thursday!
Right.
