How Can One Define a Unitary Transformation Using an Alternative Relation?
  • Context: Graduate
  • Thread starter Thread starter LAHLH
    Transformations
A unitary transformation T can be defined using two equivalent relations: (T\vec{u}, T\vec{v}) = (\vec{u}, \vec{v}) and (T\vec{u}, \vec{v}) = (\vec{u}, T^{-1}\vec{v}). The adjoint of T is defined by (T^\dagger\vec{u}, \vec{v}) = (\vec{u}, T\vec{v}), establishing that T is unitary if T^{-1} = T^\dagger. Surjectivity is essential for T to be invertible; in finite dimensions, injectivity implies surjectivity, but this is not true in infinite dimensions, as illustrated by the unilateral shift operator on \ell(\mathbb{N}).
  • Understanding of unitary transformations in linear algebra
  • Familiarity with inner product spaces
  • Knowledge of adjoint operators and their properties
  • Concept of injective and surjective functions
  • Study the properties of adjoint operators in Hilbert spaces
  • Explore the concept of isometries and their implications in functional analysis
  • Investigate the characteristics of finite vs. infinite dimensional spaces
  • Learn about the unilateral shift operator and its applications in quantum mechanics
Mathematicians, physicists, and students of linear algebra or functional analysis seeking to deepen their understanding of unitary transformations and their properties.
LAHLH
Hi,
I just have a quick question, I understand that [tex](T\vec{u},T\vec{v})=(\vec{u},\vec{v})[/tex] defines a unitary transformation [tex]T[/tex], but how does one go from this relation to [tex](T\vec{u},\vec{v})=(\vec{u},T^{-1}\vec{v})[/tex] as the other way to define a unitary transformation?
Thanks
You define the adjoint of T by [tex](T^\dagger\vec u,\vec v)=(\vec u,T\vec v)[/tex] (after proving that it always exists). Then you can define "unitary" by saying that T is unitary if [tex]T^{-1}=T^\dagger[/tex]. If T is unitary according to this alternative definition, we have
[tex](T\vec u,T\vec v)=(T^\dagger T\vec u,\vec v)=(T^{-1}T\vec u,\vec v)=(\vec u,\vec v)[/tex]
It's not much harder to prove that if T is unitary according to your definition, it's also unitary according to the alternative definition, but I'll let you do that one for yourself.
LAHLH said:
How does one go from this relation to
It's impossible. You have to require that U is surjective. Of course, if U preserves the inner product (which is LAHLH's definition) then it is an isometry (actually, these are equivalent), hence injective. Surjectivity is needed to guarantee bijectiveness, else T^-1 does not make sense. In finite dimensions injective already implies surjective, but in general (infinite dimension) not.
Consider E.g. the unilateral shift T on [itex]\ell(\mathbb{N})[/itex]which sends (x1,x2,x3,...) to (0,x1,x2,x3,...). It is an isometry, so it preserves the inner product. So T would be unitary according to the first definition. But T is not invertible (not surjective): its image does not contain sequences whose first coordinate is non-zero.
  • · Replies 20 ·
  • · Replies 0 ·
