Electric Fields near the surface of the earth
The discussion revolves around the electric fields near the surface of the Earth, specifically analyzing the forces acting on a charged honeybee. The original poster presents a problem involving the calculation of the ratio of the electric force on the bee to its weight, as well as determining the electric field strength required for the bee to remain suspended in the air.
  • Participants explore the relationship between electric force and weight, with an initial attempt to calculate the electric force based on the given charge and electric field strength. Questions arise regarding the setup for part (b) and the conditions for suspension.
There is an ongoing exploration of the calculations needed for both parts of the problem. Some participants provide guidance on how to approach the calculations, particularly in establishing the relationship between electric force and weight for the bee. The discussion reflects a collaborative effort to clarify concepts and calculations without reaching a definitive conclusion.
Participants are working within the constraints of a homework assignment, which may limit the information available and the methods they can use. There is an emphasis on understanding the underlying physics rather than simply obtaining a numerical answer.
Mitchtwitchita
A 0.10 g honeybee acquires a charge of +23 pC while flying.
(a) The electric field near the surface of the Earth is typically 100 N/C, directed downward. What is the ratio of the electric force on the bee to the bee's weight?
(b) What electric field strength and direction would allow the bee to hang suspended in the air?
E = F on q/q+
(a) E = fon q/q+
Therefore, F = Eq
= (100 N/C)(23 x 10^-12 C)
= 2.3 x 10^-9 N
Therefore, (2.3 x 10^-9)/(1.0 x 10^-4 kg)
= 2.3 x 10^-5 N/kg
(b) I don't really know how to get this one started. I think it would be directed upward though. Can someone please help me with part b and let me know if I was correct on part a?
For a) you want to get a ratio.
weight = mg. So you need to multiply 1.0 x 10-4 kg by 9.81 m/s2
For b), if the bee is suspended, the resultant force is zero. So the electric force should be the same as the bee's what ?
weight?
Mitchtwitchita said:
weight?
Right, so EQ=mg. What is E?
Ah. Therefore E = mg/q
=[(1.0 x 10^-4 kg)(9.81 m/s)]/(23 x 10^-12 C)
=4.3 x 10^7 N/C?
Yes that is correct.
  • · Replies 16 ·
