Difference between Forward and Backward Fourier Transforms?
  • Context: Graduate
  • Thread starter Thread starter dimensionless
    Difference Fourier
The discussion clarifies the distinction between forward and backward Fourier transforms, represented mathematically as F(k) = ∫ f(x)e^{-i 2π k x}dx for the forward transform and f(x) = ∫ F(k)e^{i 2π k x}dk for the backward transform. The key difference lies in the sign of the exponent, which is crucial for maintaining the reciprocal property of Fourier transforms. This property ensures that applying the transform twice returns the original signal, but it fails for odd functions unless the sign is adjusted. The introduction of the minus sign in the inverse transform allows for generalization across all signal types.
  • Understanding of Fourier Transform concepts
  • Familiarity with complex exponentials
  • Knowledge of even and odd functions in mathematics
  • Basic calculus, particularly integration techniques
  • Study the properties of Fourier Transforms in detail
  • Learn about the implications of even and odd functions on Fourier analysis
  • Explore the application of Fourier Transforms in signal processing
  • Investigate the Fast Fourier Transform (FFT) algorithm for efficient computation
Mathematicians, signal processing engineers, and students studying Fourier analysis who seek to deepen their understanding of Fourier transforms and their properties.
dimensionless
What is the difference between forward and backward Fourier transforms? I'm look:
[tex] F(k) = \int_{-\infty}^{\infty} f(x)\ e^{- i 2\pi k x }\,dx[/tex]
[tex] f(x) = \int_{-\infty}^{\infty} F(k)\ e^{ i 2\pi k x }\,dk[/tex]
If I swap the x and the k in the second equation, the transforms are then:
[tex] F(k) = \int_{-\infty}^{\infty} f(x)\ e^{ i 2\pi x k }\,dx[/tex]
and the only difference is the minus sign in the exponent. What gives? Why aren't the forward and backwards transforms identical?
Actually minus sign is introduced for generality.
Fourier transforms have reciprocal (reversible) property i.e., if you take Fourier transform on a signal two times you will end up with original signal. So if [tex]f(x) [/itex] is even function then both forward and inverse transforms can have the same sign and reciprocal property is valid. But if [tex]f(x) [/itex] is odd or neither even nor odd, then reciprocal property is lost (i.e, if you take FT two times you will end up with minus of original function) if you use same sign in forward and inverse transforms. <br /> <br /> In order to generalize Fourier transform for any signal (even, odd, neither of two) and to preserve reciprocal property minus sign is introduced.[/tex][/tex]
