Frobenius method solution for linear ODE
The discussion centers on solving the second-order linear ordinary differential equation (ODE) given by x²u'' - x(xu' - u) = 0. The correct general solution requires a logarithmic term, specifically y = C₁x∫e^x/x² dx + C₂x + x∫(e^x/x² ∫e⁻ˣ x f(x) dx) dx. The initial solution of y = x is confirmed as correct, while the subsequent solution provided by the user is identified as incorrect. The discussion references external resources for further clarification on solving similar inhomogeneous ODEs.
  • Understanding of second-order linear ordinary differential equations
  • Familiarity with the Frobenius method for solving ODEs
  • Knowledge of integral calculus, particularly integration techniques involving exponential functions
  • Experience with mathematical software like MathType for visualizing solutions
  • Study the Frobenius method in detail for solving linear ODEs
  • Learn about the method of undetermined coefficients for inhomogeneous ODEs
  • Explore integration techniques for exponential functions and their applications in ODEs
  • Review resources on variable coefficients in linear differential equations
Mathematicians, engineering students, and anyone involved in solving ordinary differential equations, particularly those interested in advanced techniques like the Frobenius method and inhomogeneous solutions.
zokomoko
I've been given the ODE:
x^2 u''-x (x u'-u)=0
Solve.
It's suppose to be an example in which a logarithmic term is required for the general solution.
I would be glad if someone could look at what I've done and see if my solution is correct / incorrect.
Thank you in advance for your time and effort :wink:
p.s: I've attached a zip file which contains a WMF type file of the problem, if anyone has mathtype it's easier to read than the attached GIF image.
  • Madar.zip
    Madar.zip
Your 1st solution of y = x is correct, but the other solution is wrong.
Please refer to the below question in http://www.voofie.com" .
http://www.voofie.com/content/86/how-to-solve-this-2nd-order-linear-differential-equation/"
The question solves an inhomogeneous version of your question using http://www.voofie.com/content/84/solving-linear-non-homogeneous-ordinary-differential-equation-with-variable-coefficients-with-operat/" .
If there is an inhomogeneous function of f(x), the solution should be:
[tex]\Rightarrow y=C_1x\int e^xx^{-2} dx+ C_2 x+x\int \left(e^xx^{-2} \int e^{-x} x f(x)dx\right) \, dx[/tex]
And you can see, the fundamental solution that you are missing is:
[tex]x\int e^xx^{-2} dx[/tex]
