Thread Closed
Calculating the average power emitted from a laser
Share Thread Thread Tools
Jun17-10, 05:18 PM   #1
I have found a 5000 volt 20 milliamp laser at a Ham fest now logic tells me the power of the laser would be simply 5000V*0.02A= 10watt input then loses would maybe make it one watt. however I really doubt that it has that much power. I haven't been able to find a power supply capable either of running the thing either because the ignition voltage is 10,000 volts! I would rather find out the power of the Laser before I go on a hunt for a power supply and I'm curious on how one can calculate the power of a laser without measuring the output beam intensity.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jun17-10, 05:40 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
If you have a 20 milliWatt laser, isn't its power 20 milliWatts or am I missing something?
Jun17-10, 09:26 PM   #3
no the rating on the side says 20 milli amps 5000 volts
Jun17-10, 09:43 PM   #4
Recognitions:
OK, so you changed your units on me. The fact that you put 10 W in does not mean that you get 10 W out. I am not an expert on this, but I would assume that he efficiency of your laser is a number you will probably have to measure, not calculate. See for example
http://www.newton.dep.anl.gov/askasc...9/eng99213.htm
http://www.rp-photonics.com/wall_plug_efficiency.html
Jun17-10, 11:32 PM   #5
I see that its what I thought, a measuring device however would be very expensive. I think however if I compare it to the efficiency of other lasers I end up with a very small rating around 50 milliwatts. The irony is that the thing is about 16 inches long and has a 2 inch diameter yet most likely has a rating only a few times greater than your average laser pointer. I guess they don't scale well. (Note by efficiency of other lasers I mean watts in watts out)
Thread Closed
Tags
calculating, laser, power output
Thread Tools
Similar Threads for: Calculating the average power emitted from a laser
Thread Forum Replies
If you know the wavelength of light emitted by a laser how can you know... Introductory Physics Homework 7
Power of a laser Introductory Physics Homework 2
Doubt about laser power in laser transmitter Electrical Engineering 4
Diffusion of laser light for measuring laser power General Physics 3
