Can Hydrogen have a DC Circuit?
The discussion revolves around the concept of modeling a hydrogen atom as a direct current (DC) electrical circuit. Participants explore the applicability of electrical equations, particularly Ohm's Law, to atomic structures, questioning whether values like impedance and energy can be used in this context.
  • One participant suggests using the characteristic impedance of the vacuum as resistance in a circuit model of the hydrogen atom, questioning the validity of using energy values in electron volts for voltage.
  • Another participant clarifies that electron volts and volts are not interchangeable, emphasizing that a hydrogen atom does not function as a DC circuit.
  • Concerns are raised about the fundamental differences between energy usage in a hydrogen atom and the continuous energy flow required in a DC circuit.
  • Participants debate the relevance of Ohm's Law, with one arguing that it is based on free electron gas models, which do not apply to atomic structures.
  • Questions arise regarding the potential energy of an electron approaching a proton and whether this can be interpreted as a form of electrical current.
  • There is a discussion about the nature of electron behavior in atoms versus synchrotron systems, with assertions that electrons do not orbit nuclei in the classical sense.
  • One participant proposes that the nucleus may also exhibit cloud-like characteristics similar to electron clouds, prompting further inquiry into the nature of electron orbits.
  • Clarifications are offered about the electrostatic potential field created by protons and how it influences electron behavior.
Participants express disagreement on the applicability of electrical circuit concepts to atomic structures, with some asserting that such models are speculative and not physically meaningful. There is no consensus on whether any numerical values can be derived or if they hold significance in this context.
Limitations include the speculative nature of applying circuit theory to atomic physics, the dependence on definitions of voltage and energy, and unresolved questions about the behavior of electrons in different systems.
kichigai
[SOLVED] Can Hydrogen have a DC Circuit?
I'm thinking of the hydrogen atom like it might be a DC type of electrical circuit, just for fun, but I am not sure what values to use for a couple of simple equations. Can somebody help me out?
The equation is V=I*R
I found an impedance value, Z, in NIST's list of constants and stuff, a factor they call "Characteristic Impedance of the Vacuum". That Z value = 376.73 ohms. Can I use that as R?
I know the BE for the H 1s electron is 13.06 eV, and it looks like I can use it for V, but I'm not sure since it has units of "eV". Can I use it for "V" as it is or do I have to change it or do something else?
Maybe I can use the charge, Q, of the electron and calculate "V" from capcitance "C" using C = Q/V, but I have the same units problem.
Thanks for any help!
Hey, maybe I can use this for a science project!
The electron-volt is a unit of energy. The volt is a unit of electrical potential. The electron volt is the amount of kinetic energy gained by electron when moved through a potential of one volt. They are not interchangeable.
Besides, the entire premise of what you're trying to do is speculative. There is no "DC circuit" inside a hydrogen atom in any respect whatsoever.
- Warren
The number 1 problem you won't be able to get around is the fact that a hydrogen atom doesn't use energy over time, while a DC circuit needs some continuously.
The number 2 problem is that Ohm's Law is based on the Drude model of FREE electron gas in a conductor. How is this anywhere similar to a hydrogen atom?
Zz.
Bummer! I was kinda hoping that I could get some kinda number even though it might not be a real number. Are you guys really sure that I can't get even a Voltage number?
Look, the reason why physics is called PHYSICS and not MATHEMATICS is because the quantity and numbers we obtain have PHYSICAL MEANINGS. You can crank out any numbers and equations that you want out of your imagination, but it doesn't mean any of these have any physical significance. If you can't show any physical significance of a number that you crank out, or why such model is valid, then any result that you arrive at is meaningless.
Zz.
- Warren
I understand. You said when an electron moves through a potential of one volt it then has one electron volt of energy. Right?
When a free electron flies toward a free proton, does the electron develop potential as it flies closer and closer to the proton? If so do you have an idea or a number for the potential when the electron is 0.53 Ang away from the proton? Can I think of that as a short burst of electrical current?
Thanks!
Zz.
Is Ohm's law involved in controlling, understanding or predicting how free electrons fly around a synchrotron loop?
If so, then it seems that the electron, in its particle form, imitates the electron beam in the synchrotron because that one electron flies around the proton of hydrogen such that the center of the synchrotron serves as the proton. What do you think of this perspective?
The beam path in a synchrotron is nothing at all like an electron in an orbital in an atom. Electrons do not "orbit" nuclei. Atoms are quantum-mechanical systems, while synchrotrons are not.
- Warren
- Warren
yet QM-processes occur in synchrotrons
regards
marlon
regards
marlon
While that is technically true, it isn't what is used in the majority of the dynamical description of a synchrotron. Classical E&M is alive and well in terms of beam physics, and the same can be said for describing the electron beam in a synchrotron. So Chroot is correct in saying that a synchrotron is a "classical" system.
Zz.
Thanks!
Did I get skipped?
I liked the answer given to What are electrons, but didn't see anything about my question. Can you give me a hint? Thanks!
- Warren
The nucleus is understood to have a shell structure with orbits that imitate the shell structure of the electrons. Are the neutrons and protons delocalized like the electron clouds and as a result do not "orbit" or move around inside the nucleus in a structured manner? This implies that the nucleus should also be a cloud like system. This arrangement would suggest that there is there is a great deal of spherical symmetry within the nucleus.
What is it that tells us that electrons do not orbit?
Thanks!
I am guessing that you either haven't studied E&M much, or if you did, you haven't fully understood it yet.
1. An electron going through a potential difference of X Volts will GAIN an kinetic energy equal to X eV.
2. The proton in "electron develop potential as it flies closer and closer to the proton" is IRRELEVANT. All that proton does is to be the SOURCE of the electrostatic potential field that the electron sees, the SAME potential that is in #1. When you have the potential field due to that proton, then you can ignore that proton and simply deal with the resulting field. This field is what is causing ALL the relevant interaction on that electron.
3. For a finite, bound charge, by definition, the zero value of the electrostatic potential is at infinity from the source charge. So all the electrostatic potential values are "calibrated" from this zero value. You can then calculate ALL the necessary energy gain or loss by that electron at ALL locations to your heart's content once you know this and #2.
4. Useful websites such as Hyperphysics has the electrostatic potential field for point and spherical sources.
Zz.
How about the fact that, in its rest state, the electron has no angular momentum? Seems hard to describe it as an "orbit" with no angular momentum...
Zz.
Indeed, but relativistic and QM-notions are also to be taken into account when looking for a complete description of the synchrotron and what it does.
regards
marlon
regards
marlon
Relativistic, yes. It takes no effort to get a bunch of electrons to the relativistic regime. But where exactly would "QM-notions" come in?
Zz.
Zz.
Well, when an incident particle at high speed interacts with an atomic nucleus, don't we need QM (or QFT) in order to describe what happens. I mean fission and fusion are processes where the QM-regime can be applied, not ?
Maybe I am looking at this to much in terms of the theory-aspect. I am thinking of processes like fission described in terms of the strong-force mediating pions intechanged between hadrons.
Please, let me know if I am exagerating...
regards
marlon
regards
marlon
Humm... I could have sworn that we are talking about a "synchrotron" here.
A synchrotron is an electron storage ring. The APS here at Argonne has a ring with a circumference of almost 3/4 of a mile. In it, bunches of electrons just go round and round and round and round... There are no collisions with anything. In fact, collision is BAD! We don't want them since it will degrades the beam quality.
It is this that I insisted that classical physics is alive and well, and that there are no QM effects that are significant enough that QM description has to be used.
Zz.
Ok, humm, in the case of the synchrotron, you are right. I know this what we were initially talking about.
The remarks I made concerning QM and special relativity where made as a remark to high-energy-collisions and more generally high-energy-physiscs.
Sorry, i must have confused You.
regards
marlon
Never heard of anyone actually bringing an electron to rest, so I wonder if that is a relevant point since particles are never at rest. At rest seems to be a useful reference point, that does not however exist sort of like an imaginary number. Yes?
Zz.
Are you saying that Ohm's law does not apply to the operation of the Synchrotron beam?
:bugeye:
Rest state, as in not excited. More specifically, the lowest electron energy level around the hydrogen atom. The electron has a probability distribution around the nucleus, but has no angular momentum. This is an obvious reason that calling it an "orbit" is a really bad analogy.
hydrogen atom...ohms law... well ohms law is really for macro scale objects for a start, the resistance is not allowed to varie on the amount of current or voltage applied... what could you image for R in a hydrogen atom?... well anyway...
from past experience just telling someone its not a valid question doesn't seem to solve there problem and get pretty upset, so...
As the classical idea of an electron "orbiting" a hydrogen atom isn't correct... SO IS THE FOLLOWING... but if you really wanted to float your boat and it makes you happy... i guess you could work out how fast an electron would have to be traveling to actually orbit a proton at a certain radius... from balancing F=mv^2/r and F=kq1q2/r^2 and then going by what the definition of electron current, number of electrons per second through a conductor... but in this case i suppose you would use the cross sectional area of an electron... but this electron in the classical sense is in perpetual motion... so as soon as you tried to make it do work you would loose your current...
also looking at it another way... you have a proton... a positive charge source... performing pd = - integral(E.dl) (where E, dl are vectors and the . is the dot product and the pd is the potential difference (measured in Volts)) doing this on any closed loop (circuit) around the proton the p.d will be found to be zero. so no p.d no current around the loop.
but given that DC implies a single direction for the current and
from QM's uncertainty principle you can't get a DC
because you would not get the same direction for the electron every time you took a measurement.
I was originally talking about the flow of "pseudo current" between the proton and the electron because I read somewhere that "virtual electrons and photons" are shared (exchanged?) through the empty space in between the proton and the electron. The voltage difference is the difference in voltage difference between the proton and the electron. I understand that electrons flows from negative to positive and thought the "virtual" electrons would do that. It seems like the virtual photons would be the return circuit. So, I'm trying to describe a flow of current from the electron to the proton and back. Can you guys tell me if that is OK or not?
Thanks! I really appreciate your advice above. I'll do some study and see what stuff falls out.
Whoa! This is worse than I thought! :)
There are no "virtual electrons" flowing in between the electron and the nucleus! The "electrostatic" potential that exists between the electron and the positive nucleus can be transformed into virtual photon interactions within the QFT/QED formulation. There are no "currents" here, either virtual, real, or imaginary. You could have saved a lot of time and effort if you had clearly stated this way in the beginning.
So it appears that this thread was based on a faulty premise. Can we finally put it out of its misery now? :)
Zz.
Indeed, I am also convinced these last post were rather, eeuuhh speculative hmmm?
I agree with ZapperZ
regards
marlon
Zz.
Ouch! You guys are kinda blunt. Didn't know I had to be so perfect in my writing when I don't even know that much. I kinda thought you guys would help me out to understand, not get mad at me 'cause I don't know enough to write down all the important details. I'm a HS student tryin' to learn some physics stuff that's interesting. Never said I was in college. Is there another forum that can help people like me who don't know so much physics as you guys.
Don't know where I gave a faulty premise or was speculative. You said there are no virtual electrons, but virtual photons are okay. What about photoinduced currents, you know light sensor things. They get a photon and make electrons flow. Why can't that happen in an atom?
kichigai,
We have no problem with you not knowing things -- we have a problem with you not knowing things, then making posts saying what you think about physics.
- Warren
  • · Replies 18 ·
  • · Replies 32 ·
