A Challenge Problem in Techniques Of Problem Solving
The discussion revolves around finding a formula for the sum of squares of the first k positive integers, specifically S = 1² + 2² + 3² + ... + k². Participants are exploring methods to derive this formula, referencing a previous example problem that illustrates a telescoping series approach.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants suggest using the identity (k+1)³ - k³ = 3k² + 3k + 1 and applying summation techniques. Others mention the method of summing contiguous numbers and relate it to the formula for S.
Some participants have provided hints and suggested manipulations, while others have reported progress in finding the formula for S. There is an acknowledgment of different approaches being explored, but no explicit consensus has been reached on a single method.
Participants note that this is a self-study problem rather than a homework assignment, indicating a focus on understanding rather than completing an assigned task.
AK2
I just need a hint to solve the problem. The method used is illustrated in the example problem as follows:
Assume that k is a positive integer . What is the sum of integers
S = 1+2+3+...+(k-1)+k?
Solution:
22 - 12 = 3 = 2 * 1 + 1
32 - 22 = 5 = 2 * 2 + 1
42 - 32 = 7 = 2 * 3 + 1
k2 - (k-1)2 = 2 * (k-1) + 1
(k+1)2 - k2 = 2 * k + 1
Now we add the columns:
[22 - 12] + [32 - 22] +...+ [(k+1)2 - k2]
= [2 * 1+1] + [2*2+1] + [2*3+1]+...+[2*k+1]
The left hand side ''telescopes'' (that is, all but the first and last terms cancel) and the right side may be factored. The result is
(k+1)2 - 12 = 2[1+2+3+...k] + [1+1+1+...+1]
k times
or
k2 + 2 * k = 2 * S + k
Solving for S for we find that
S = (k2+k)/2
I am supposed to imitate the method used in the example problem to solve the challenge problem in the book as follows
Imitate the method used in the last problem to find a formula for the sum
12 + 22 + 32 + ... + k2
when k is a positive integer.
I have tried various things like (a+1)4 - a4, (a+1)3 - a3, triangle numbers, odd numbers, but I haven't been able to solve it. I just need a hint. This is not a homework problem. This is self study.
Use
[tex](k+1)^3 - k^3 = 3k^2+3k+1[/tex]
and do summation on both side. By telescoping method, only 2 terms left in the left hand side. You need to do a little manipulation on the right hand side though.
Why not like the Contiguous Numbers: for example,P=1+2+3+4+5...+100 and the answer of P is (1+100)*100/2 , so the S=(1+k)*k/2
ross_tang said:
Use
Thanks for the hint
I got my answer for S
S = (2k3+3k2+k)/6
You are right. You may want to do some factorization also.
[tex]S = \frac{ n(n+1)(2n+1)}{6}[/tex]
