| Thread Closed |
Verification of moment of inertia calculation |
Share Thread | Thread Tools |
| Jun19-10, 03:59 PM | #1 |
I was looking at the moment of inertia list that they have on Wikipedia and noticed that the moment of inertia for a regular polygon was rather complicated. I did the calculation myself and found a significantly simpler result of
I = (m/6)(3+tan(pi/n)^2)*R^2: m is the mass of the polygon, n is the number of edges of the polygon, R is the length of the line segment from the center of the polygon to one of its edges, where the line segment is perpendicular to that edge. I just wanted to verify that this is correct; I can submit a proof of how I calculated this if need be. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jun19-10, 04:18 PM | #2 |
How about testing it out first for a few known polygons.If n is infinity you will have a thin solid disc for which the MI=(mR^2)/4.I think your equation gives (mR^2)/2
Whoops,we need to clarify this.If the axis of rotation is through the centre and at 90 degrees to the plane of the disc then the MI=(mR^2)/2.If you are considering the same axis then your equation seems to give the right answer.Try some other polygons. |
| Jun20-10, 08:45 AM | #3 |
moment of inertia of square:
[tex]I_c=\frac{m(h^2+w^2)}{12}=\frac{m(2h^2)}{12}=\frac{m(\sqrt{2}R)^2}{6}=\ frac{mR^2}{3}[/tex] but your formula shows: [tex]I_c=\frac{2mR^2}{3}[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Verification of moment of inertia calculation
| Verification: Hanging mass on cylinder. Moment of inertia | Introductory Physics Homework | 5 | ||
| Moment of inertia calculation, factor of radius out? | Introductory Physics Homework | 6 | ||
| Moment of Inertia Calculation | Introductory Physics Homework | 2 | ||
| Moment of Inertia Calculation | Advanced Physics Homework | 16 | ||
| What are moment of inertia, mass moment of inertia, and radius of gyration? | Introductory Physics Homework | 1 | ||
