Ramjet Engine: How Does It Work at Subsonic Speeds?
  • Thread starter Thread starter Gazza2907
    Engine Ramjet
The ramjet engine operates efficiently at supersonic speeds due to the compression of air caused by shock waves, which increases pressure before combustion. At subsonic speeds, ramjets are ineffective as they rely on high-speed airflow to function; thus, an auxiliary engine, such as a turbojet, is necessary to achieve the required velocities. The enclosed design of the ramjet does not allow for effective air expansion at lower speeds, leading to a lack of thrust generation. Understanding these principles is crucial for aerospace engineering applications involving jet propulsion systems.
  • Basic understanding of thermodynamics and fluid dynamics
  • Familiarity with jet propulsion concepts
  • Knowledge of supersonic and subsonic flight dynamics
  • Experience with aerospace engineering principles
  • Research the operational principles of turbojet engines
  • Study the effects of shock waves on airflow in ramjets
  • Explore the differences between ramjet and scramjet technologies
  • Learn about the design considerations for high-speed aircraft propulsion
Aerospace engineers, students studying propulsion systems, and aviation enthusiasts interested in jet engine technology and performance optimization.
Gazza2907
I think i know how the ramjet works at supersonic speeds, because of the shock wave the air particles traveling through the inside of the tube converge and bump into each other and because the air cannot expand it slows down, increasing the pressure, so when the air escapes it expands very quickly accelerating the rocket.
But how does this system work without the shock wave (at subsonic speeds) does the air just move through the tube slower because it's an enclosed space and the air can't expand if it the particles bump into each other?
Anything else you know about how the ramjet works would be good as well.
  • · Replies 16 ·
  • · Replies 35 ·
  • · Replies 45 ·
  • · Replies 26 ·
