How Do You Calculate Acceleration from Velocity?
  • Thread starter Thread starter Shay10825
    Acceleration
The discussion revolves around calculating acceleration from given velocity and position data in a physics context, specifically focusing on motion along the x-axis with constant acceleration. The original poster seeks assistance in determining acceleration during a specified time interval based on position changes.
  • Participants explore the relationship between position, velocity, and acceleration, questioning how to derive acceleration from velocity without using kinematic equations. There are discussions about the need for additional information to determine initial conditions and the implications of missing data.
The conversation includes various attempts to clarify the problem setup and the relationships between the variables involved. Some participants suggest that the original poster may have omitted critical information, while others discuss the implications of having or lacking specific data points. There is an ongoing exploration of how to approach the problem using derivatives and the concept of average velocity.
Participants note that the problem involves a constant acceleration scenario, but there is a debate about the adequacy of the provided information to solve for velocity or acceleration without additional data points. The original poster expresses confusion regarding the calculations and the relationship between slope and acceleration.
Shay10825
find the acceleration. PLEASE HELP!
Hi
Find the acceleration.
from x= 2m to x= 8m during a 2.5-s time interval.
I found the slope to be 2.8 so the velocity is 2.8. Now how do I fond the acceleration? I know you have to find the slope of the velocity to get the acceleration, but i keep geeting the wrong answer :cry: .
The answer is .32 m/s^2
~Thanks
I think we're missing some information or you provided incorrect numbers.
If the acceleration is 0.32 m/s^2 then an object will move 1 m in 2.5 seconds under uniform acceleration and starting from rest.
the problem said:
A particle confined to motion along the x-axis moves with constant acceleration from x= 2m to x= 8m during a 2.5-s time interval. The velocity of the particle at x=8 m is 2.8 m/s. What is the acceleration during this time interval?
I know how to do it with the kinematic equations but I want to do it without them. How would you do it with derivatives?
You left the "The velocity of the particle at x=8 m is 2.8 m/s." out of the original post- that's the "missing information" Tide was talking about.
If we take the constant acceleration to be "a", and initial velocity to be "v0", then the acceleration after t seconds is at+ v0 and the postion is
(1/2)at2+ v0t+ 2 (the original position was x= 2).
You are told that when t= 2.5, (1/2)a(2.52)+ v0(2.5)+ 2= 8 and a(2.5)+ v0= 2.8.
Solve those two equations for a and v0.
at+ v0[/b
Sorry :redface: .
How come when you find the slope of the v= 2.8 and t=2.5 it does not equal the acceleration of .32 :confused: ?
because you need another point to determine the slope, not just when v = 2.8. and t = 2.5. You can determine the initial velocity and use that as the second point.
so (Vf-Vi)/2.5 = acceleration?
but how come (2-8)/2.5 does not = 2.8? How would I fond the slope for the velocity?
because there's an acceleration, the slope for velocity is always changing, thus, you can find the average velocity using (y2-y1)/(x2-x1).
-->(8-2)/(2.5-0) = average velocity.
How would I find the slope or derivative of the velocity at 2.8m/s and t=2.5 (the answer is .32m/s^2 but how would we find this ).
Shay10825 said:
How would I find the slope or derivative of the velocity at 2.8m/s and t=2.5because it is .32m/s^2.
no need for calculus here. Besides, they already told you the slope for the velocity at t = 2.5. It's 2.8m/s. But that's not what you're asking for, since .32m/s^2 is the acceleration.
figure out vi using (vi+vf)/2 = average velocity.
You already know the average velocity.
once you have it. a = (vf-v1)/(2.5)
I understand all of that but say if this was a different problem and they did not give you the 2.8. How would you find it (2.8) using derivitaves and the information (2 m, 8 m and 2.5 sec)?
Then you wouldn't be able to solve it. There's not enough information given.
so if you had A particle confined to motion along the x-axis moves with constant acceleration from x= 2m to x= 8m during a 2.5-s time interval. Find the velocity of the particle at x=8 m you would not be able to solve it because there is not enough info?
that's correct.
But I thought the slope or derivative of the displacement or position time graph is the velocity at that time? If it did not say "a 2.5 s time interval" but said specific points then would you be able to find the derivative or the velocity?
Yes, then can you figure it out... if you're given a graph and all...
:cool: THANK YOU SOOOOOO MUCH! :biggrin: :wink: I just started AP Physics B and it's all new and so hard :frown: .
  • · Replies 38 ·
  • · Replies 17 ·
