Can the decay process of Nickel-78 be stopped?
  • Context: Graduate
  • Thread starter Thread starter jerich1000
    Stable
The discussion centers around the possibility of halting the decay process of Nickel-78, specifically through Beta-minus decay. Participants explore the mechanisms of this decay and whether any steps in the process can be interrupted while still retaining the identity of Nickel-78.
  • One participant questions how Nickel-78 could be made stable while remaining Nickel-78, outlining the decay process involving the transformation of a neutron into a W-boson, which subsequently decays into an electron and an antineutrino.
  • There is a suggestion that halting any step in the decay process might be theoretically considered, though the initial response indicates that the quick answer is likely no.
  • Another participant humorously suggests that if someone were to offer an infinite amount of money, it would still not change the impossibility of halting the decay process.
  • A later reply reinforces the idea that halting Beta-decay is not feasible and proposes that it might be more practical to focus on creating a constant supply of Nickel-78 instead.
Participants generally agree that halting the decay process of Nickel-78 is not possible, though there is some light-hearted debate about the implications of having infinite resources to attempt such a feat. The discussion remains largely exploratory without a consensus on any potential methods.
Participants express uncertainty about the feasibility of halting the decay process and acknowledge the complexities involved in the Beta-minus decay mechanism. There are no detailed mathematical or physical corrections provided, and the discussion remains speculative.
This discussion may be of interest to those exploring nuclear physics, decay processes, and the theoretical limits of particle stability.
jerich1000
I'm somewhat new here, so forgive me if I ask an inappropriate question (defined as too far out there; this is supposed to be a legitimate site).
How could it be possible to make Nickel-78 stable, and still remain Nickel-78?
Nickel-78 decays via Beta-minus decay, which means one of its neutrons is turned into a W-boson, which in turn decays into an electron and an antineutrino.
Through the process, one down quark is turned into an up quark, which means it's a flavor change, which means the process is a "weak decay", or decay via the weak force.
I've listed the above info to highlight that there are a number of steps invovled in the entire transition. Can any of those steps be halted, thereby halting the decay process?
The quick answer, of course, is no. But if someone were to hire you for an infinite amount of money to stop the process , what change to the process could you make?
Thanks
Thanks
There is no way that I know of to do what you describe, unless money has some magical ability to halt beta-decay.
I was expecting the answer, "No, but can I have the money anyway?"
That would also be a really good answer. :) All kidding aside, I don't think it's possible. You would be better off using that money to make a constant supply of Nickel-78, right?
  • · Replies 0 ·
  • · Replies 0 ·
