Difference between heat, thermal energy, and temperature
The discussion revolves around the distinctions and relationships between heat, thermal energy, and temperature within the context of thermodynamics. Participants explore definitions and implications of these concepts, particularly in relation to energy transfer and the states of matter.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant defines heat as the energy transfer due to temperature differences, while thermal energy is described as the total kinetic and potential energy in a substance, and temperature as the average energy per particle.
  • Another participant asserts that thermal energy and temperature are related to kinetic energy, suggesting that potential energy is not included in these definitions, citing the example of ice at 0°C where added heat does not change temperature or thermal energy but changes the state of the substance.
  • A question is raised about whether thermal energy also encompasses potential energy, indicating a potential area of confusion or debate.
  • Another participant expresses uncertainty about the definition of thermal energy, noting that internal energy and enthalpy involve both kinetic and potential energy of molecules.
Participants express differing views on the definitions and relationships between thermal energy, temperature, and potential energy, indicating that the discussion remains unresolved with multiple competing perspectives.
The term "thermal energy" appears to lack a universally accepted definition among participants, leading to ambiguity in its relationship with kinetic and potential energy.
Snazzy
This isn't really a homework question per se. I'm studying for my MCAT and I'm having trouble trying to firmly get down some of the concepts in thermodynamics.
As far as I know, heat is the means of energy transfer that isn't work from one substance to another due to a difference in temperature between the two substances.
Thermal energy is the total amount of kinetic and potential energy in a substance.
Temperature is the average (per particle) amount of kinetic and potential energy in a substance.
So something that has a lower temperature, like a big chunk of ice, may have more thermal energy than something like a small heated nail.
Am I on the right track? I'm not too sure whether temperature/thermal energy is a measure of potential energy and kinetic energy, or just one or the other.
Thanks for your help.
Thermal energy and temperature refer to kinetic energy, and not potential energy. For example, it when you add heat to ice at 0oC, the heat does not change the thermal energy or temperature of the ice. Instead the heat changes the ice into water, increasing the potential energy of the water molecules.
Is not thermal energy also related to the potential energy of the molecules?
It depends what you mean by thermal energy (I'm not so sure this is a well defined term). Certainly the internal energy and enthalpy of molecules are dependent on both the kinetic and potential energy of the molecules.
  • · Replies 0 ·
  • · Replies 30 ·
