How do i solve the system of equation
  • Thread starter Thread starter lorik
    System
The problem involves solving a system of three linear equations with three variables: a, b, and c. The equations are a+b-c=0.1, 2a-b-c=0, and a+b+c=0.3.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods to isolate variables, including subtracting equations and substituting values. There is also mention of using Cramer's Rule as a potential approach.
Participants are actively engaging with the problem, offering different strategies for solving for the variables. Some have provided specific steps to follow, while others are exploring the implications of the equations without reaching a consensus on a single method.
There is an emphasis on understanding the relationships between the variables and the equations, with some participants questioning the original poster's manipulations of the equations.
lorik
I need to find a,b,c from
a+b-c=0.1
2a-b-c=0
a+b+c=0.3
The furthest I've gone is
a+b+c=0.1
3a=0.3=>0.1
NOW PLEASE HELP ME HOW TO SOLVE FOR B AND C ?
im not sure what you have done?
you can start by subtracting the first equation from third equation, then you will have the value of c
after that you can use this value in the second equation to get either a in terms of b or b in terms of a, after that you can easily substitute again in the first or third equation to get your answer..
a+b-c=0.1
2a-b-c=0
a+b+c=0.3
a+b+c=0.1
3a=0.3=>0.1
You lost your variable! 3a = .3 ==> a = .1
Now substitute for a in two other equations to get two equations in b and c, which you can solve for those variables.
What you did the first time was add the second and third equations, eliminating both b and c at the same time to get a= .1.
Now, you can, as Mark44 suggests, set a= .1 in those three equations reducing to two equations for b and c. (Only two equations because a= .1 makes the second and third equations, that you used to get a, the same.)
Or you can do as Thebigstar25 suggests- subtract the first equation from the third equation. That eliminates both a and b at the same time, allowing you to solve for c.
Once you have found a and c, put those values into any of the three equations and solve for b.
Ok thanks for the fast reply because it really helped !
I do not know if you have learned about Cramer's Rule, but you might want to look into this, it will make this problem very simple to solve.
  • · Replies 18 ·
  • · Replies 21 ·
