Is liquid helium composed of both ortho and para-helium?
  • Context: Graduate
  • Thread starter Thread starter Creator
    Helium Liquid
The discussion revolves around the composition of liquid helium at low temperatures, specifically whether it contains both ortho and para-helium or is solely in the ground state para-helium. Participants explore the implications of singlet-triplet splitting, decay processes, and experimental conditions for generating triplet helium.
  • One participant questions whether liquid helium contains both ortho and para-helium or only para-helium at low temperatures, suggesting that ortho is a meta-stable state.
  • Another participant notes the large singlet-triplet splitting (~20 eV) and suggests that helium should be entirely in the ground state unless special conditions exist, such as the creation of triplet-helium BECs.
  • There is a discussion about the decay of triplet helium, with some participants mentioning that it can decay radiatively but not via a single-photon process, and that the decay may occur through two-photon processes.
  • Participants explore methods for generating triplet helium, including the use of specific wavelengths to excite helium from the singlet ground state.
  • There is mention of collisional processes being the most probable decay method for non-isolated helium, where two triplet-helium atoms can collide and exchange electrons.
  • One participant expresses uncertainty about the temperature required for sufficient kinetic energy to enable spin flips in triplet states and whether mechanical means could facilitate collisional spin flips.
  • Another participant corrects their earlier claim about the lifetime of the He(2S^3) state, indicating it is approximately 8000 seconds, which they describe as surprisingly long for a meta-stable state.
Participants express differing views on the presence of ortho and para-helium in liquid helium, the decay processes involved, and the methods for generating triplet helium. The discussion remains unresolved with multiple competing perspectives.
Participants highlight limitations in understanding the decay processes, the dependence on experimental conditions, and the complexity of the interactions in non-isolated helium. There are unresolved questions regarding the temperature dependence of spin-flip rates and the specifics of collisional processes.
Creator
In a batch of liquid helium (say < 8* K.) is there a mixture of both ortho and para-helium, or is it only ground state para-helium.?
I was under the impression that ortho was a meta-stable state which cannot decay to ground state Para-helium by radiative emission, but by meta-stable we are talking only a fraction of a second...right?
What am I missing here.?
Anyone?
IIRC, the singlet-triplet splitting is quite large, ~20 eV. So it should be entirely in the ground state, unless there are special conditions going on (they've made triplet-helium BECs).
It can decay radiatively, just not by a single-photon process.
Thanks alxm...
What special conditions are you referring to ? How do I create triplet state experimentally?
So if triplets decay after 1/10 second (is that about correct?) then by what process do they decay?
Well I was thinking if you specifically generate triplet helium and then cool it in an optical trap or similar. Not exactly your usual state of affairs.
This is a 'forbidden' transition; It can only occur (in an isolated atom) due to two-photon processes, which one can think of as a decay to a 'virtual' level in-between the two states. For Helium it's not symmetric; one of the photons carries more energy than the other, so you end up with two peaks, one at ~70 nm and one at ~2400. (See e.g. http://link.aps.org/doi/10.1103/PhysRev.180.25" , if you want some details)
1/10 of a second.. I'm not sure. An isolated 3He atom would probably have a lifetime orders of magnitude longer. But with gaseous or liquid helium, in a container, etc, you have many more interactions that can go on and assist the process. (For instance formation of a He2 molecule in the [tex]^3\Sigma_u^+[/tex] state.)
alxm said:
Well I was thinking if you specifically generate triplet helium and then ..
That was my other main concern: By what method would you "specifically generate triplet helium"??(not BEC)
Thanks for the G W Drake link. I'm not too sure I understand it all...Of course, Selection rules prohibit single photon transitiion ... so it goes two photon route...OK, but this rate is extremely low, right?
I have read elsewhere that the most probable decay is thru 'collisional' process, I am not sure what that refers to ...any info there?
GW Drake has a later article in which it appears as if he is saying that there is a MORE probable Magnetic dipole transition to ground state decay...am I reading that right?
See here:
http://cos.cumt.edu.cn/jpkc/dxwl/zl/zl1/Physical%20Review%20Classics/atomic/099.pdf
Creator
I haven't researched it, but off the top-of-my head you could simply irradiate the helium with a wavelength that excited it from the singlet ground state to a state that was able to decay to the triplet state. Given that that state has a relatively long lifetime, this should give you all the triplet helium you want, given that the radiation is sufficiently intense.
.OK, but this rate is extremely low, right? I have read elsewhere that the most probable decay is thru 'collisional' process, I am not sure what that refers to ...any info there?
Yes, that's the most probably situation for a non-isolated helium, and in practice the most common decay method. The easiest and most common is simply that two triplet-helium atoms collide and exchange an electron (or viewed another way: flip each other's spins). That process is fairly straightforward.
It appears so. Guess I was wrong. Given that it appears Breit and Teller also thought the two-photon process was more likely, at least I'm in excellent company! :-p
Both forms of decay are certainly many orders-of-magnitude less significant than the collision route, in a 'normal' environment. This is all mostly of astrophysical interest, since space is full of helium atoms in high vacuum.
Thanks again, Alxm. and sorry for the late response.
The collisional process is interesting...apparently, collision with a container wall can also do the trick.
1st question: At what temperature is there enough kinetic energy to spin flip each He triptlet state? Probably somewhere there is a temperature dependent rate formula?
2. Can collisional spin flip be by mecahnical means, (ex,rotation of the fluid) ?
After further reasearch it appears as though I was wrong about the 1/10 sec. excited lifetime.
The He(2S^3) state lifetime is about 8000 seconds! That's a quantum eternity, and surprising...probably the longest"Meta-stable" state around...but makes sense knowing the fact that it is radiatively forbidden transition to ground.
Creator
  • · Replies 21 ·
