Are angle measurements rank 0 tensors?
The discussion revolves around whether angle measurements can be considered rank 0 tensors, particularly in the context of different reference frames, including those that are accelerating or moving at relativistic speeds. Participants explore the implications of special relativity and the invariance of angles in various scenarios.
  • Some participants propose that in a flat metric and with inertial reference frames, angle measurements can be considered invariant due to the Lorentz invariance of the dot product of vectors.
  • Others argue that while angles may appear invariant in non-relativistic contexts, relativistic effects such as Lorentz contraction can alter perceived angles for observers in different frames of reference.
  • A participant questions whether invariance holds for angles in accelerating frames, even at low speeds, suggesting that acceleration might affect measurements.
  • Another participant asserts that instantaneous acceleration does not affect angle measurements, emphasizing that only instantaneous velocity is relevant.
  • There is acknowledgment that while non-relativistic speeds may allow for practical invariance, significant acceleration could complicate the situation.
Participants express differing views on the invariance of angle measurements, particularly in the context of acceleration and relativistic speeds. The discussion remains unresolved regarding the effects of acceleration on angle measurements.
Participants note that the discussion assumes inertial frames and does not fully resolve the implications of acceleration on angle measurements, highlighting the complexity of the topic.
e2m2a
If I measure an angle in one reference frame to be 90 degrees, would it be 90 degrees with respect to all other reference frames? That is, is angle measurement a rank 0 tensor? I'm assuming all other reference systems are at non-relativistic velocities.
In flat metric, yes. You can look at an angle as inverse cosiine of the dot product, and dot product of two Lorentz vectors is Lorentz-invariant.
Edit: The part that's implied here is that the coordinate system is inertial. If it's accelerated, that messes with your metric.
What if the accelerating coordinate system is far below relativistic speeds. Would invariance still exist for the angle measurement to a good approximation?
Or does speed not have anything to do with it, only acceleration. If this is the case, if a coordinate system accelerated only at a small fraction of g and far below relativistic speeds, would invariance still exist for the angle measurement to a good approximation?
Disregarding relativity, yes, the angle between two vectors is invariant. An accelerating observer will see the same angle as a nonaccelerating observer. A rotating observer will see the same angle as a nonrotating observer. The angle between two vectors is as constant as things get.
When you throw Einsteinian relativity into the mix, the angle between two vectors is NOT invariant. Let's declare you to be at rest. You draw a square on the ground. Pick a corner. One side coming out of that corner is called "side A" and the other is "side B." Now draw a diagonal line from your corner to the opposite corner. Call this line "diagonal D." Now the angle between side A and diagonal D is 45 degrees, and so is the angle between B and D.
I get in my rocket and move at, um, 87% of the speed of light in a direction parallel to side B. Then when I look at the square, I'll see Lorentz contraction: side A will look the same to me as to you, but side B will appear only half as long. So from my perspective, the square is now a rectangle where the angle between A and D gets smushed to 27 degrees and the angle between B and D stretches to 63 degrees, but you still think it's a square and that the angles are 45 degrees each.
But again, if we ignore Einsteinian relativity, lengths and angles do not appear to change just because the observer is moving or accelerating.
Ok, I understand, due to Lorentz contraction, how a moving observer at relativistic speeds would observe a different angle measurement than an observer in the frame where the angle measurement is at rest. I also understand at non-relativisitc speeds, exact invariance would still not exist, but the difference would be so trivial we could ignore it.
Its the acceleration that I'm not sure of. Let's say initially the frame is at rest. An observer in that frame is making his angle measurement. A second observer would agree with the measurement that observer is making because since the frame is at rest, both observers are in the same frame.
Now, at some point in time, the frame begins to accelerate with respect to the second observer at a huge acceleration rate. Now we compare the measurements of the two observers 1 pico second later from the time the frame began its acceleration, such that the speed of the frame hasn't had the time to acquire any significant speed and is far below relativistic speeds. Let's say relative to the second observer its instantaneous speed is 1 centimeter per second.
Invariance of the angle measurement for all practical purposes would still exist because of the non-relativistic speed of the frame, but because the frame is accelerating at that instant at a huge rate, would invariance break down-- soley due to the acceleration alone?
Invariance of the angle measurement for all practical purposes would still exist because of the non-relativistic speed of the frame, but because the frame is accelerating at that instant at a huge rate, would invariance break down-- solely due to the acceleration alone?
No, instantaneous acceleration never makes a difference, even when we take relativity into account. Only your instantaneous velocity will affect angle measurements.
Thanks for clarifying this problem for me.
  • · Replies 30 ·
