Equivalence Principle question
The discussion revolves around the implications of the Equivalence Principle, particularly in a hypothetical universe where inertial mass and gravitational mass are not equal. Participants explore how this scenario would affect everyday experiences and the interpretation of weight and acceleration.
  • Some participants propose that if gravitational mass were twice the value of inertial mass, then a 1 kg mass would weigh differently under different conditions, such as in space versus on Earth.
  • Others argue that the force measured by scales is determined by inertial mass, suggesting that scales would show the same reading regardless of the hypothetical changes in mass.
  • A participant questions whether the proposed changes in mass would manifest as indicated in their experiment, seeking clarification on the implications of the proportionality constant.
  • Some participants highlight that the equivalence means inertial mass is proportional to gravitational mass, not necessarily equal, and changing the proportionality constant would alter the acceleration due to gravity.
  • One participant acknowledges a flaw in their thought experiment, realizing that the concept of acceleration is tied to gravity and cannot be independently calibrated in the hypothetical scenario.
  • Another participant emphasizes that the scenario discussed is unphysical and irrelevant to our universe, questioning the validity of the assumptions made about the equivalence principle.
  • Some participants discuss the relationship between the laws of inertia and gravity, pondering whether they are fundamentally the same phenomenon or merely equivalent observations.
Participants do not reach a consensus, as there are multiple competing views regarding the implications of the Equivalence Principle and the hypothetical scenario presented. Disagreement exists on how changes in mass would affect measurements and the interpretation of gravitational versus inertial mass.
Limitations include the dependence on the definitions of mass and the unresolved nature of how changes in the proportionality constant would affect gravitational acceleration. The discussion also reflects uncertainty about the implications of the equivalence principle in hypothetical scenarios.
Buckethead
According to Einstein's Equvalence Principle inertial mass and gravitational mass are interchangable. If we lived in a universe where these two masses were not equal, how would this translate into everyday experience? For example, if gravitational mass were twice the value of inertial mass would the following be true?:
A 1 kg mass is accelerated at 32 ft/s^2 in space. The mass is weighed on a scale calibrated to this experiment and therefore shows the mass to weigh 1 kg.
The 1 kg mass and scale are placed on the surface of the Earth (where acceleration due to gravity is still 32 ft/s^2) and the mass is shown to weigh 2 kg according to this scale.
Thanks.
Thanks.
If the two masses were not equivalent, then your equation of motion, in Newtonian physics would look like this:
[tex]m_i\frac{d^2r}{dt^2}=-\frac{GMm_g}{r^2}[/tex]
instead of the well-known form:
[tex]\frac{d^2r}{dt^2}=-\frac{GM}{r^2}[/tex]
That is, the proportionality constant changes from 1 to [tex]\frac{m_g}{m_i}[/tex]
In addition to this, the Eotvos experiment and its reenactments would look totally different.
Thanks for the reply. So in my hypothetical universe the proportionality constant is 2. Does the result of this constant change manifest as indicated in my experiment?
That's not how it works. In your experiment, the force is determined by the inertial mass, and as all scales show force, their reading would be the same.
The "equivalence" means that inertial mass is strictly proportional to gravitational mass, not that they are "equal". The proportionality constant is G. If G were different, the surface acceleration of Earth would be different, but you still couldn't tell a gravitational field from acceleration.
Are you sure? For the acceleration part of the experiment I set the force to be such that the acceleration of the weight is 32ft/s^2 or the same as the acceleration on all bodies caused by gravity. I can do this since I have control over the acceleration force. That being the case, in our universe a scale calibrated on Earth would show the weight of the object as 1 kg as would be the case if the weight were put on the same scale in an elevator in space being pulled at 32ft/s^2. The reason is because the inertial mass is equal to the gravitational mass. Now if the inertial mass were suddently to increase to twice it's mass (in our hypothetical universe) then the weight in the elevator (remember it's still going 32ft/s^2) would now show twice the weight it did before or 2 kg. Since the gravitational mass in the hypo universe (by definition of the experiment) remains unchanged, the scale would read 1 kg when the mass was weighed on Earth. Would this not be correct?
What you have done in your thought experiment is induce a local gague transformation on G. G=G(t).
Your scale is now out of calibration. It measures incorrectly by a factor of 2.
That's different from your scenario. You had constant -but different- G, which would not violate the equivalence principle. You'd calibrate the elevator to 64 ft/s² (try sensible units next time :wink: ), because that's the Earth surface acceleration in that universe.
If you change G after calibrating, that's obviously a difference.
I did switch the experiment around a bit, but the concept of the question remained the same. However, I just realized a flaw in the experiment. I suggested accelerating the elevator at 32ft/s^2 but this would be impossible to determine (I think) if not for a scale calibrated on Earth. You could not use the rocket motors as a ruler as the inertial mass of the exhaust would also be different in the hypothetical universe. I now see how it is impossible to make the inertial mass and gravitational mass equal (as opposed to equivalent) as the concept of acceleration is really related to a measure that originates from gravity. It is not separately calibratable.
I was indeed suggesting the equivalence principle was being violated as this was the heart of the question. I was sure to mention a hypothetical universe where the equivalence principle did not hold and was trying to determine how such a law would then manifest.
Of course it's possible to determine acceleration. The point is that, in your original experiment, you wouldn't have 10 m/s² on earth, but 20 m/s², and the force is the same again.
We do not live in such a universe. Your point is irrelevant and unphysical.
Yes, of course you are right, it's possible to determine acceleration (brain fart on my part)
The key point in my experiment is that the gravitational mass and inertial mass are different. If the gravitational mass of an object is 2x the inertial mass, then an object accelerating at 10m/s^2 in space will experience a certain weight, let's say 1kg. If that same object were then to be placed on a scale on a planet that had a gravity that caused a freefall acceleration of 10m/s^2 then why would the object not weigh 2 kg? If it still weighs a 1kg then I'm totally missing the meaning of gravitational and inertial mass.
Now I understand that in this universe this is not a parameter that can be adjusted, so I'm indeed speaking hypothetically.
I'm baffled by this. Am I wrong in saying that the Equivalence Principle is a principle based on an observation about 2 entirely different laws. The law of inertia and the law of gravity. They so far (that I am aware of) have not been shown to be one in the same phenomenon, only equivalent for some unknown reason. Or did Einstein determine that they are indeed one and the same phenomenon, unseparable even speculatively?
You have two laws with potetially different meanings of mass:
[tex]F_i=m_i a[/tex]
[tex]F_g=m_g \, GM_g/r^2[/tex]
Now if we set mg=2*mi
[tex]F_g=4m_i \, GM_i/r^2[/tex]
but also
[tex]a_g=4GM_i/r^2[/tex]
and thus
[tex]F_i=m_i a_g = 4m_i \, GM_i/r^2 = F_g[/tex]
since you accelerate your rocket (by the setup of your experiment) with the acceleration you observed at Earth's surface.
You get observable differences only if the ratio mg/mi differs with the composition of the test bodies.
but also
and thus
To get from here
[tex]F_g=4m_i GM_i/r^2[/tex]
To here:
you are assuming that:
ag=Fg/mi
but you can only say that ag=Fg/mg or ag=Fi/mi as mg and mi are not the same in this hypothethical universe. Correct? (sorry I'm not able to use latex, it keeps putting up old symbols that I erased, go figure).
  • · Replies 99 ·
  • · Replies 44 ·
  • · Replies 36 ·
  • · Replies 36 ·
