Thread Closed
Setting up a double integral to find the volume
Share Thread
Jun27-10, 10:13 PM   #1
Set up and evaluate a double integral to find the volume of the solid bounded by the graphs of the equation
x2+y2+z2=r2
2. Relevant equations
Not much equations, just setting the integral up, however I have no idea.
3. The attempt at a solution
I know how to approach these problems if there were only 2 variables, but I'm kind of stuck since there are three variables that I have to deal with.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jun27-10, 11:35 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by ahmetbaba View Post
x2+y2+z2=r2
Then solve the equation for z, giving one or more functions of two variables.
Is there any obvious symmetry you can use?
Jun27-10, 11:38 PM   #3
how can you solve the equation for z, even then there will be r^2. Help me out with the beginning here please.
Jun27-10, 11:44 PM   #4
Recognitions:
r is just a constant. Do you recognize what the graph of this is?
Jun27-10, 11:49 PM   #5
do we approach this problem by first saying z=o, then x=o and y=o, integrating all three equations. However the question says to set up a double integration, not a triple integration?
Jun27-10, 11:55 PM   #6
Recognitions:
No, you don't do that. So I will ask you again:
1. Do you recognize what this surface is?
2. Can you use any symmetries to your advantage?
Then solve it for z to get started. Get z in terms of x and y if you are required to do a double integral.
Jun27-10, 11:58 PM   #7
well it is a sphere, we can say that the center of the sphere passes through (0,0,0) so if we calculate the top half, we can multiply by 2, to get the answer.
z=sqrt(r^2-x^2-y^2)
the limits being -r and r for the first integral, and sqrt(r^2-y^2) and -sqrt(r^2-y^2)
is this correct so far?
Jun28-10, 12:46 AM   #8
Recognitions:
z=sqrt(r^2-x^2-y^2)
You have the right idea. You might want to change your dxdy integral to polar coordinates to make it easier. If you do that, you might first change the r in the equation of the sphere to a so you don't confuse it with the r in polar coordinates. Good luck. I'm off to bed.
Jun28-10, 01:36 AM   #9
x2+y2+z2=r2 is a sphere..
try using spherical coordinates.
set up a triple integral, and do one integration to get to the double integral :)
Thread Closed
Tags
double integral
Similar discussions for: Setting up a double integral to find the volume
Thread Forum Replies
Setting up a triple integral to find volume of a region Calculus & Beyond Homework 7
use double integral to find the volume Calculus & Beyond Homework 2
Double integral Find Volume? Calculus & Beyond Homework 2
Use a double integral to find volume of solids ? Calculus & Beyond Homework 3
Find the Volume (Double Integral) Calculus 2
