Flux attenuation, given interaction cross section
The discussion focuses on calculating the outgoing neutron flux after it interacts with a target material, specifically aluminum, using the neutron interaction cross section and the incoming neutron flux. The interaction cross section for 10 MeV neutrons on aluminum is approximately 2 barns per atom, which translates to an attenuation coefficient (μ) of 0.12 cm-1. The formula for the flux at a given penetration depth (x) is defined as F(x) = F0 e-μx, where F0 is the incident neutron flux. This mathematical approach allows for precise calculations of neutron interactions within materials.
  • Understanding of neutron interaction cross sections
  • Familiarity with attenuation coefficients in nuclear physics
  • Basic knowledge of exponential decay functions
  • Proficiency in using Avogadro's number and atomic weight in calculations
  • Study neutron interaction cross sections in various materials
  • Learn about the applications of the attenuation coefficient in radiation shielding
  • Explore the derivation and applications of the exponential decay formula in nuclear physics
  • Investigate advanced neutron flux measurement techniques
This discussion is beneficial for nuclear physicists, radiation safety professionals, and researchers involved in neutron transport calculations and material interactions with neutrons.
thefury
It strikes me that this may well be fairly easy, but i can't quite get my head round the correct way to lay this problem out (at least in a mathematical sense).
If you are considering a neutron flux onto a fully understood material, and you also know the neutron interaction cross section of the target object and the flux of the incoming neutrons, should it be possible to calculate the out going flux (i.e. on the reverse side of the target) ?
I'm guessing that the cross section and the number density of the atoms in the target will give you an effective target size, from which you could calculate a probability of interaction (i think?). Then this may be a simple task to apply to a given flux through a material of selectable thickness to give a final flux and/or number of neutrons that should have interacted with the material.
any help would be appreciated, i think i just need a good nudge in the right direction.
Here is an example.
10 MeV neutrons on aluminum target. Cross section (n,total) is ~ 2 barns per atom.
σ = 2 barns per atom = 2 x 10-24 cm2 per atom
N0 = 6 x 1023 atoms per mole (Avagradro's number)
A = 27 grams per mole (atomic weight)
D = 2.7 grams/cm3 (density)
μ = attenuation coefficient (cm-1)
μ = σN0D/A = 0.12 cm-1
If the incident neutron flux is F0, the flux at penetration x is
F(x) = F0 e-μx
Bob S
  • · Replies 20 ·
