| Thread Closed |
Generating orbital files with TURBOMOLE |
Share Thread | Thread Tools |
| Jun29-10, 09:08 AM | #1 |
Hi,
This question might be a little too specific, but does anyone know how (or where I might find literature) to generate basis set files used by the program TURBOMOLE. I am attempting to fit simple gaussian orbitals to dummy atoms but no luck so far. Thanks |
| Jun29-10, 09:32 AM | #2 |
Recognitions:
No problem. (Although I'm not sure if you want to read them or write them?) The format looks like this (example is the 6-31G basis for carbon)
Code:
$basis
c 6-31G
6 s
3047.5249000 0.0018347
457.3695100 0.0140373
103.9486900 0.0688426
29.2101550 0.2321844
9.2866630 0.4679413
3.1639270 0.3623120
3 s
7.8682724 -0.1193324
1.8812885 -0.1608542
0.5442493 1.1434564
1 s
0.1687144 1.0000000
3 p
7.8682724 0.0689991
1.8812885 0.3164240
0.5442493 0.7443083
1 p
0.1687144 1.0000000
$end
Code:
$basis * <element> <basis set name> * <# primitive gaussians> <shell type> data <# primitive gaussians> <shell type> data * <element> <basis set name> * <# primitive gaussians> <shell type> data * $end So you say how many primitive Gaussians ([tex]de^{-\alpha r^2}[/tex]) your radial function has, and s/p/d/f (and so on) to specify the angle-dependent part. And each line after has the exponent ([tex]\alpha[/tex]) followed by the contraction coefficient ([tex]d[/tex]). Note that these are unnormalized values. Otherwise it's fairly straightforward. |
| Jun29-10, 11:11 AM | #3 |
Many thanks for the help. I have written a simple basis file and turbomole has accepted it.
One last question: I have generated a couple of dummy points using turbomole's define program, and assigned them simple gaussians. It seems to be going ok, until I try and generate molecular orbitals from these dummy atoms. Normally I would do an eht calculation in turbomole's 'occupation number & molecular orbital definition' define menu, but it (rightly) tells me I have no electrons in my 'molecule' and refuses to give me a mos file. I have tried manually inserting electrons using the 'man' option, but am still unable to get molecular orbitals. Is my 'molecule' too unphysical for turbomole? Is there a step I'm missing? I notice the same thing happens when I remove nuclear charge from normal atoms like H2. Thanks again for the help. |
| Jun30-10, 01:56 PM | #4 |
Recognitions:
Well, are you saying you're trying to do a calculation without any nuclear charges anywhere? That won't work; it shouldn't even converge!
What's your goal here? |
| Jul1-10, 05:07 AM | #5 |
My goal is essentially to create an electron(s) that are free from any atomic nuclei, but still have a bound state (kind of like a particle in a box). It is unphysical, but I am really only interested in the type of molecular orbitals it generates (No geometry optimisation or anything like that), as it might save me some analytical legwork.
I have generated a hydrogen atom thousands of angstroms away from my dummy atoms, and not given it a basis set, in the hope that this will force the charge onto my dummy atoms. It is horribly contrived but it might work. |
| Jul1-10, 08:01 AM | #6 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: Generating orbital files with TURBOMOLE
| Orbital Velocity vs Mass and Orbital Velocity vs Radius | Introductory Physics Homework | 2 | ||
| zts-files and don't know how to open them | Computing & Technology | 2 | ||
| daa files | Computing & Technology | 2 | ||
| HDF files for f90/95 | Programming & Comp Sci | 1 | ||
| .rar files | Computing & Technology | 11 | ||
