Velocity of object sliding down incline, given gravity and the incline's height
The problem involves a cart sliding down an incline with a height of 159m, where the initial speed is 0m/s and gravity is 9.8 m/s². The challenge is to determine the cart's speed at the bottom of the hill while neglecting friction and air resistance.
  • The original poster attempts to use kinematic equations but expresses uncertainty about the lack of time and the angle of the incline. They consider treating the motion as freefall but question the validity of this approach.
  • Some participants suggest using conservation laws, particularly energy conservation, to analyze the problem without needing the mass of the object.
  • Questions arise regarding the application of conservation of energy and the implications of not knowing the incline's angle.
Participants are exploring different approaches, including kinematic equations and conservation of energy. There is a recognition that energy conservation could simplify the problem, despite the lack of certain variables. No consensus has been reached, but productive ideas are being shared.
Participants note the absence of the incline's angle and the object's mass, which are constraints in applying certain methods. The discussion reflects a focus on understanding the principles involved rather than seeking a definitive solution.
jstep
a cart slides down an iced incline that is 159m high.
acceleration of gravity is 9.8 m/s^2
neglect friction, air resistance
determine carts speed at the bottom of the hill
v = u + at, but no time is mentioned
v^2 = u^2 + 2ah, if i treat it like freefall
i don't hardly know where to start with this one, my first instinct was to break the two-dimensional motion into component vectors. but then i realized i don't have the length of the incline or even the angle of the incline, only the height.
i don't have any notion of time either, so i can't use v = u + at
i could treat it like freefall and use v^2 = u^2 + 2ah
v = sqrt(u^2 + 2ah), u = 0
v = sqrt((2)(9.8)(159))
v = 55.82 m/s
but i don't believe i can treat it like freefall, because aren't you supposed to be able to break up two-dimensional velocity into vectors that are completely independent of each other? and i believe the question is asking for the v in the x direction.
i'm not asking for an answer, i need to understand how to do it myself. but i don't think I'm approaching this problem with the right process. I think i just need a nudge in the right direction.
Thank you.
Thats why we love conservation laws. :smile:
What is constans during ride down?
regards
the only thing that is constant is acceleration in the y-direction, acceleration in the x-direction is increasing. are you speaking of conservation of energy? I don't understand how that applies to this scenario... I don't even have the object's mass.
Energy is constans and of course I suggest use energy conservation law. To apply this you should assume, that you are know mass - it will be reduced.
The beauty of the conservation of energy law lies in the fact that no matter what happens in the meantime. No matter distance, time etc. You know energy at the start time, and at the end. They are equal. Thats all.
regards
Bartek
ps
of course you can solve this using classical movement equations. You have to assumed that you know the angle of hill, then find distance and qravity force component parallel to hill. No matter, that you in fact don't know that angle - it will be reduced.
  • · Replies 18 ·
  • · Replies 24 ·
