| Thread Closed |
What is the most accurate gravitational force equation? |
Share Thread | Thread Tools |
| Jul1-10, 03:18 AM | #1 |
The Newtonian gravitational force formula is F=G([m1*m2]/D^2)
Using limits, it has the property that as D goes to zero, F goes to infinity. Did Einstein fix this? If so, what's his equation for gravitational force? Please accommodate me by defining all terms so I can work with it. Thanks, Jake |
| Jul1-10, 06:40 PM | #2 |
Recognitions:
Even Newton's law has a practical problem as D -> 0, namely the fact that the objects have a non-zero size.
Simple example - two balls of non-zero radius. D is the distance between the centers and has a minimum value of the sum of the radii. |
| Jul1-10, 07:11 PM | #3 |
| Jul2-10, 12:42 AM | #4 |
Do point masses actually exist though?
| Jul2-10, 07:22 AM | #5 |
if point masses don't exist then what's the alleged problem for Newton?
| Jul2-10, 07:43 AM | #6 |
Mentor
One big problem with Newtonian gravity is that it implicitly assumes an infinite transmission speed for the gravitational force. Another problem is that Newtonian gravity does not quite match reality; in a sense this is an even bigger problem than the first problem. For example, the discrepancy between what Newtonian mechanics said Mercury's should look like and what astronomers saw was an open problem at the end of the 19th century. General relativity solved both of these issues.
| Jul3-10, 03:50 AM | #7 |
So what's Einstein's equation for gravitational force?
| Jul3-10, 04:37 AM | #8 |
If you want to map that back to Newtonian terms, the main difference (for "weak field" situations such as in the solar system) is that space is curved and "shrinks" slightly relative to a typical coordinate system which can be applied around a central mass. This adds a term to the force law which depends on the square of the speed. In the simple case of a dominant central mass with lighter objects moving around it, such as the solar system, the usual practical convention is to use "isotropic" coordinates, in which the speed of light relative to the coordinate system varies slightly with potential but the scale factor at any point is the same for the x, y and z directions. Basically, rulers shrink by (1-Gm/rc2) and clocks run slow by the same factor, which means that relative to the coordinate system the speed of light is decreased by the square of this factor, approximately (1-2Gm/rc2). In that case, the force law for a particle of total energy E moving with momentum p = Ev/c2 in a Newtonian gravitational field g is as follows: dp/dt = (E/c2) g (1 + v2/c2) You can also divide both sides by the energy to get the following: d(v/c2)/dt = (1/c2) g (1 + v2/c2) Note that this is expressed in terms of coordinate values, which differ slightly from local values. In particular, c in the above expression is the coordinate speed of light (which depends on potential), not the local standard value. This is effectively the same as a special relativity extension of the Newtonian force plus an extra v2/c2 term due to the curvature (and scale factor) of space. This means that the rate of change of coordinate momentum for something moving at (or near) the speed of light is twice what Newtonian theory alone would predict. Note that the above rate of change of momentum does not depend on the direction of travel; it applies regardless of whether the test particle is travelling tangentially, radially or anywhere in between. Also, the rate of change of momentum is directed exactly towards the source (at least in this simplified case where only the central source has a significant mass), which means that angular momentum is conserved too. For something moving downwards at the speed of light c, it may seem odd that its momentum is increasing, but if you look at the momentum expression Ev/c2 you will see that for speed of light travel, the momentum is E/c, where E is constant for free fall, but c decreases (slightly) as you get closer to the source. In contrast, the expression for the rate of change of velocity (that is, acceleration) is much more complicated and depends on the direction of travel. |
| Jul4-10, 06:10 AM | #9 |
Jonathan, you describe a perhaps possible and certainly tempting view on GR.
However how do you explain things past the event horizon? The speed of light, in this view, would have to become imaginary, or do I misunderstand completely what you are saying? |
| Jul4-10, 06:42 AM | #10 |
The same isotropic coordinate system (where the coordinate speed of light remains the same in all directions) can be used in combination with the Schwarzschild solution to describe strong gravity, although it is more conventional to use Schwarzschild coordinates. The physics is unaffected by the choice of coordinate system (in the same way as the layout of the Earth is unaffected by the projection used to map it). |
| Jul4-10, 06:48 AM | #11 |
Again, it is very interesting view but I think problematic past the event horizon of for instance the Schwarzschild metric. I was simply interested if you had a perspective on this. |
| Jul4-10, 04:47 PM | #12 |
I've never even thought about whether isotropic coordinates can be continued past the event horizon; it seems likely to run into trouble, because "inwards" and "outwards" are physically different, but I don't have time to look at it at the moment. Perhaps you could look up the standard transformation between isotropic and Schwarzschild coordinates and try it out yourself. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: What is the most accurate gravitational force equation?
| Gravitational Force equation | Introductory Physics Homework | 2 | ||
| Solution of equation of free fall of a particle in a gravitational force field | Introductory Physics Homework | 0 | ||
| Free body diagram involving normal force, gravitational force, and applied force. | Introductory Physics Homework | 4 | ||
| Unifying Gravitational Force Equation | General Physics | 5 | ||
| Lie-detector glasses:Air Force tests 90% accurate! | General Discussion | 1 | ||
