| Thread Closed |
Interpreting F=ma |
Share Thread | Thread Tools |
| Sep1-04, 12:40 PM | #1 |
Interpreting F=ma
I've asked a couple of professors, how can you say F=ma is empirically true unless you define what F and m are. Each basically said they didn't have a perfectly good answer to that question. The most obvious answers (in my opinion) lead to circular definitions. Well, I was thinking about this and I can up with the following (perhaps sloppy) way of making sense of things.
We define the mass of any uniformly composed rock to be one kilogram. Then we say that the mass of any similar rock that is twice as large has twice the mass (or one half the size has half the mass). We now say that the mass of two bodies are equal if they balance an equal-arm balance near the earth. By empirical observations we note that mass is time-invariant and transitive (i.e. if m1 = m2 and m1=m3, then m2 = m3). Now we know what it means to say the mass of a particular system is x kilograms. Let us now define the center-of-mass of a body of uniform composition to be at its geometrical center. The center-of-mass of any other body is then the limit of breaking up this body into smaller pieces of approximately uniform composition and summing up their mass-weighted geometrical centers. Now when we talk about the acceleration of a body, we are really talking about the acceleration of its center-of-mass. Finally, we define the net force on a body to be equal to the product of its mass and acceleration (perhaps it is more appropriately defined in terms of momentum). Now we can state Newton's Law (an empirical observation) in this form [edit: actually, i'm not so sure this is a 'form' of his law]: The net force acting on a body (the central body) when surrounded by other bodies (the surrounding bodies) is equal to the sum of the net forces that would act on the body if the each surrounding body were considered in turn as an isolated system with the central body. I know some of the definitions (such as the one involving an equal-arm balance) aren't entirely precise, but at least its something, which is always better than nothing. |
| Sep1-04, 12:53 PM | #2 |
the actual definition if force is:
[tex] F = \frac{dp}{dt} [/tex] |
| Sep1-04, 01:00 PM | #3 |
I'm afraid my professors are not that dumb (i.e. not just say so it if the answer were so simple). The question would now become "what is momentum"? And even if you answer this, then you would not be able to say what the force is acting between two particular bodies when the system is compromised of three or more bodies because only the net force acting on a body equals the rate of change of momentum.
| Sep1-04, 01:26 PM | #4 |
Recognitions:
Interpreting F=maSecondary standards are made by using a balance to compare the secondary standards to the primary standards. The most precise standards are made out of the same alloy (platinum-iridium) as the primary standard (more uniform and easier to control than rock). Stainless steel standards are also used, but are less precise due to buoyancy problems with air displacement. Apparently cycling the standards to and from vacuum has its own problems, though I don't quite understand why. http://www1.bipm.org/en/si/si_brochu...dix2/mass.html |
| Sep1-04, 01:50 PM | #5 |
hmm, my point wasn't to come up any sort of precise standard for mass. Just to make a definition without the use of forces so that none of the definitions are circular.
| Sep2-04, 04:36 AM | #6 |
Recognitions:
Newton did not just formulate his laws, he also had to define the notions like momentum and force. Ofcourse people had a intuitive feel for what a force was at that time, but it wasn't defined quantitatively until Newton. Momentum ofcourse is defined as mv, which Newton called "quantity of movement" or "quantity of motion." (can't remember which). These are fundamental introductions of physical quantities as mathematical objects, so we can work with it. You cannot derive it from anything else, so you cannot help but be circular in your reasoning. Even mathematics is circular in it's roots. There exists no formal definition of a 'set' (but everyone has a feel for what it is). If you try to define it, you end up using words like 'collection' or so, but it doesn't solve the problem: how would ou then define 'collection'? The point is that these concepts are intuitively clear enough. Think of it like this: Mathematics/physics is a language and any language is circular in reasoning. Take a dictionary of say the English language. If you search for a definition of a word, it is explained in other words which must be part of the dictionary. You can look for the meaning of those words, but the dictionary has only finite size, so you'll end up with circular reasonings eventually. |
| Sep2-04, 04:47 AM | #7 |
Newton used "quantity of motion", or at least, that was the word used in the first English translation of "Principa"
(Incidentally, the Norwegian equivalent of "quantity of motion" (bevegelsesmengde) is the most common word we use (occasionally using "momentum" instead)) |
| Sep2-04, 05:24 AM | #8 |
Recognitions:
In the Netherlands we use 'Impuls' for momentum.
For rotational equivalent with respect to some point we add the word 'moment'. So angular momentum is 'impulsmoment', which translates to 'moment of momentum'. It's actually quite logical. Torque translates to 'moment of force'. 'Moment of inertia' follows quite logically. 'Impulse', in English is the integral of Force with respect to time. Actually, I don't know what that is called in Dutch (couldn't be Impuls). |
| Sep2-04, 10:25 AM | #9 |
I don't think the tricky part is in defining either force or acceleration.
The problem lies in defining mass. Now most of you guys would seem to claim that mass is something we can simply "feel". Perhaps you percieve of mass as the amount of "stuff" in the system. In that case, we might wonder about single particles (like an electron, quark, etc.), do they have different mass because their is more stuff in one than the other? Does the amount of "stuff" in a body increase as it approachs the speed of light? If a photon has no mass, then how can it exist (should be no "stuff" there)? I think clear definitions can help us from frustrating over these kinds of questions that are, in a sense, meaningless. In my definition of mass (and I'm not trying to claim it's perfectly clean), I am trying to define mass as a property of a body [free from forces]. Nothing more, nothing less. We could then notice some empirical observations about mass (time-invariance, transitvity, additivity, etc.). This would, in a way, rebuild our conceptual understanding of mass, but on a more fundamental level. Before we simply intuited the fact that the mass of a system consisting of several bodies was their sum, but now we would see that this is really an observation (well, i guess that might depend on how you actually define mass). In any case, even if you disagree, I just hope you see my point. |
| Sep2-04, 11:07 AM | #10 |
Mentor
2. Your definition of mass ("... as a property of a body [free from forces]. Nothing more, nothing less....") is so vague, you could fit in a dozen trailer trucks in there. This does nothing in advancing of our understanding of what it is. 3. Were any of your professor condensed matter physicists? If they were, I'm surprised they did not point out to you that another definition of mass (effective mass) DOES exist as defined by the dispersion relation between energy and crystal momentum in a solid. Lest you think this has no relevance in defining what the mass of a "bare" particle is, let's not forget that Peter Higgs took this concept right out of condensed matter to fomulate the Higgs field as the origin of mass in the fundamental particles. 4. If you have a problem with "mass", how come you don't have a problem with "charge"? After all, there is a completely analogous expression for charge: F = qE. Can you completely decouple all those quantities from each other to arrive at an independent determination of "q"? 5. If you think you have a problem with "mass", just wait till you get to "spin". Zz. |
| Sep2-04, 11:25 AM | #11 |
| Sep2-04, 11:43 AM | #12 |
i think ZapperZ's point about F=qE was that it is similarly difficult to define the concepts of charge and the electric field without circular definitions.
| Sep2-04, 11:47 AM | #13 |
Mentor
I should have qualified what I meant by "analogous", even though I think I explained it in the next sentence of that posting. I was pointing out the similarities in terms of the inability to "decouple" the three quantities, the same way the original argument was made on the apparent inability to independently determine F, m, and a in F = ma. The concept of "charge" is irrelevant unless it is in an EM field, and so are intimately tied to it. So this is the "analogous" argument that can be made similar to a measurement of "mass" and "force". Zz. Ah, thanks DarkEternal. I'm glad I just didn't imagine the point I was trying to make there. I could have been clearer though, so I'm glad da_willem gave me the opportunity to clarify. |
| Sep2-04, 12:00 PM | #14 |
2. sorry, I suppose this is my fault, but when i said "my definition of mass", I was referring to my first post. you might want to read that a little more carefully. 3. okay.. that's fine. indeed it could serve as a good basis. as a first year student in physics, i wasn't about to think about that one, so i'll just stick with my equal-arm balance approach for now. it's like the trig functions, initially they are defined in terms of a unit circle, but as your knowledge increases they are defined in terms of a series. 4. okay, i didn't think about charge simply because i haven't gotten there. so, yes, maybe i am jumping the gun by considering these concepts so early. you would probably have to consider it all together, but i wouldn't rule out the possibility that you could decouple them. 5. this is just a guess, but "spin", "mass", "charge".. these are all similar properties, namely they are a quantification of a property that a system appears to possess. if you come up with a good way to define one of them, then you could possibly use analogous techniques to define the others. I'm not trying to cause any mayhem here. So please don't get so agitated. I'm just saying "hey, we could do better than this." I think many people do sometimes ask meaningless questions because these definitions are not clear. So i think it's to everyone's benefit. |
| Sep2-04, 02:03 PM | #15 |
Mentor
So to criticize the fact that a "mass" is not a valid "property" simply because it cannot exist by itself but has to be in conjuction with other quantites is missing the WHOLE POINT of assigning those properties in the first place. We give things a set of properties BECAUSE we want to know how they would interact and behave in conjuction with other quantites! If not, who cares what properties that thing has, because it does and affects nothing. In any case, shouldn't you be busy batting down the hatch before Francis shows up? Zz. |
| Sep2-04, 02:36 PM | #16 |
. No serious, sorry I interpreted your claim wrong. I only scanned the topic when my eye fell on that sentence. I should have known better and read all of it...
| Sep2-04, 05:01 PM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Interpreting F=ma
| Help interpreting a differential transpose | Calculus | 1 | ||
| Help interpreting a simple circuit? | Electrical Engineering | 3 | ||
| Interpreting Graphs | Introductory Physics Homework | 12 | ||
| Interpreting Graphs | Introductory Physics Homework | 2 | ||
| Interpreting spectra | General Astronomy | 5 | ||
