| Thread Closed |
Small Coding Problem for Excel Macro |
Share Thread | Thread Tools |
| Jul2-10, 06:08 PM | #1 |
I want to code a macro that will take in an integer as a row number and insert two rows above that row. This will repeat in a for loop. The problem is that I'm not familiar with VB syntax. Here's what I have so far:
Sub Insert_Rows_Loop() Dim CurrentSheet As Object Dim x As Integer ' Loop through all selected sheets. For Each CurrentSheet In ActiveWindow.SelectedSheets For x = 14 To 418 ' Insert 2 rows depending on values of a1 and a2. CurrentSheet.Range("a" & x &:"a" & (x+1)&").EntireRow.Insert Next x Next CurrentSheet End Sub There is some sort of syntax error in the CurrentSheet.Range argument. How does one specify a range with a variable? Thanks. |
| Jul4-10, 11:45 AM | #2 |
Try this...
CurrentSheet.Range("a" & x & ":a" & (x+1)).EntireRow.Insert |
| Jul8-10, 09:58 PM | #3 |
Thanks, but that just deleted everything :) I found another macro to use.
| Thread Closed |
| Tags |
| excel, macro, visual basic |
| Thread Tools | |
Similar Threads for: Small Coding Problem for Excel Macro
| Thermodynamics / micro/macro connection problem | Introductory Physics Homework | 4 | ||
| IFORT Coding Problem (Simpson's Rule) | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Cell formula promlem - Excel macro | Programming & Comp Sci | 2 | ||
| Excel Problem | Computing & Technology | 3 | ||
| Sort and format a protected Excel worksheet with a macro | Computing & Technology | 0 | ||
