Solving Solids of Revolution: Cylinder vs Function of Y
  • Thread starter Thread starter Telemachus
    Revolution Solids
The discussion revolves around the topic of solids of revolution, specifically comparing the disk method and the cylindrical shell method for calculating volumes. Participants explore the mathematical formulations associated with each method and their applications in different scenarios.
  • Conceptual clarification, Mathematical reasoning
  • The original poster attempts to understand the relationship between the volume formulas for solids of revolution when using functions of y versus the cylindrical shell method. Some participants provide insights into the geometric interpretations of the methods, discussing the significance of the orientation of rectangles used in each approach.
Participants are actively engaging with the concepts, with some confirming the original poster's understanding of the methods. There is a recognition of the importance of visual aids, such as diagrams, in clarifying the differences between the two methods. The discussion reflects a mix of exploration and clarification without reaching a definitive conclusion.
The original poster shares experiences from a recent exam, highlighting specific misunderstandings related to the application of the methods. They mention errors stemming from misinterpretation of the problem statements and the importance of careful reading and diagramming in solving such problems.
Telemachus
Hi, well, I don't have to solve any problem yet. I have an inquietude about solids of revolution. I've been reading this: http://en.wikipedia.org/wiki/Solid_of_revolution and this: http://en.wikipedia.org/wiki/Disk_integration
What I wanted to know is if its the same this equation than the other:
This one:
Wikipedia said:
Function of y
If the function to be revolved is a function of y, the following integral will obtain the volume of the solid of revolution:
[tex]\color{red}\pi \int_c^d {\left[R(y)\right]}^2\ \mathrm{d}y[/tex]
And this one:
Wikipedia said:
Cylinder method
The cylinder method is used when the slice that was drawn is ''parallel to'' the axis of revolution; i.e. when integrating ''perpendicular to'' the axis of revolution.
The volume of the solid formed by rotating the area between the curves of [tex]f(x)[/tex] and [tex]g(x)[/tex] and the lines [tex]x=a[/tex] and [tex]x=b[/tex] about the ''y''-axis is given by
[tex]\color{red}}V = 2\pi \int_a^b x f(x)\,dx[/tex]
I think I'm getting it now... The second one is to derive the function under the curve (or between the curve and the X axis) around the Y axis, and the first derives between the curve and the Y axis around the Y axis. Is that right?
Bye, and thanks off course.
Yes, you have it. If you draw the corresponding dy (in the first one) and dx (in the second) rectangle and revolve it about the given axis, you will see the first one generates a disk of thickness dy and the second generates a cylinder or shell of thickness dx. The integrands are just the standard formulas.
Disk: [itex]dV = \pi r^2 dy[/itex] where r = R(y)
Shell: [itex]dV = 2\pi r h dx[/itex] where r = x and h = f(x).
You seem to be getting the basic Idea of it. I find for any volume question, it is always useful to draw a diagram including the bounded area being revolved to produce the solid, a typical approximating rectangle and either a disk/washer or cylindrical shell. The diagram will help you determine which method is best for the particular question. Additionally, when you are trying to understand the difference between cylindrical shells and revolution disk method, accompanying diagrams really help.
Here is a generic example of a solid by revolution disk method:
[PLAIN]http://img85.imageshack.us/img85/944/diski.png
Notice how the rectangle is perpendicular to the axis of rotation.
Here is a generic example of a solid by cylindrical shells method:
[PLAIN]http://img341.imageshack.us/img341/1791/cylindrical.png
Notice how the approximating rectangle is now parallel to the axis of rotation.
Thanks to both of you. Sorry I haven't posted anything till now. I've already had the exam (and I've approved), and I went on a travel to Buenos Aires, so I've been away for a few days.
Well, about this topic, on the exam I had one error on the solids of revolution. When it asked to revolve an integral round the line y=6, I've revolved it on the line x=6, it was an misinterpretation due to the reading, and if I would used a diagram as you said I wouldn't commit that mistake, cause I thought of the line x=6 due to a fast read, and as I went direct to the equations I didn't realize of it, cause first it asked to make the solid with the integral of the equation around the x axis, and then around the line y=6, and when I road "y" I thought of a line parallel to the y-axis and there was the mistake. A diagram would cleared what the exercise was asking.
I had two more mistakes, one was with the definite integral of an equation involving absolute value, I didn't consider the two curves on [tex]f(x)=x|x|[/tex]. And the other was setting the equations (didn't asked to solve, just setting it) for the perimeter given by two curves and a line. In the last case, when I set the equations, I didn't realize that in one case I had a denominator involving an x on the derivative on the equation that gives the perimeter. One of the curves, which was [tex]y=x^{1/2}[/tex], didn't realize that I couldn't consider the derivative on the point 0, needed to set the perimeter of the definite integral, which goes from the point zero to an other number. I think that I should redefined the equation of the derivative on that point.
Bye there.
  • · Replies 30 ·
