Selection Rules for EM Dipole Radiation
The discussion revolves around the selection rules for electromagnetic (EM) dipole radiation, particularly focusing on the conditions under which electrons transition between bound states. Participants explore the implications of parity changes and conservation of angular momentum in these transitions.
  • One participant notes that parity must change during transitions and questions the angular momentum value associated with the dipole operator, suggesting it relates to spherical harmonics.
  • Another participant states that photons have spin 1, which implies an angular momentum of j=1.
  • There is a discussion about the expansion of dipole radiation into spherical harmonics, with a suggestion that only those with l=1 can represent a dipole.
  • A later reply provides a matrix element expression for dipole moment transitions and discusses the conditions under which these transitions yield non-zero values, emphasizing the importance of changes in quantum numbers.
  • One participant introduces a recursion relation for integrating the associated Legendre polynomials, reinforcing the condition that Δl = ±1 for dipole transitions.
Participants generally agree on the significance of parity changes and the conservation of angular momentum in dipole transitions. However, there are varying explanations and approaches regarding the mathematical details and implications of these rules, indicating that multiple perspectives remain in the discussion.
The discussion includes complex mathematical expressions and derivations that are not fully resolved, and assumptions regarding the applicability of certain models and equations are not explicitly stated.
Dumbleboar
hey,
I was asking myself a few questions about the selection rules for EM dipole radiation which occurs if electrons "jump" into lower bound states according to the selection rules.
now I know that the full explanation about matrix elements of the dipole operator comes from fermi's golden rule... which I will learn next semester... but apart from that...we have 2 considerations:
1) Parity... parity has to change... ok i got this
2) Conservation of angular momentum:
we have
ji=j[tex]\gamma[/tex] + jf
and we assume that
j[tex]\gamma[/tex]=1
WHY is this angular momentum 1??
I guess it has something to do that the cartesian components of the Dipole operator are proportional to linear compinations of the spherical harmonics Y1,m but I don't get this point at all...
I'd highly appreciate your help!
thanks in advance
Ok Photons have Spin 1... therefore they have j=1
but i guess you can also explain it through expanding the dipole radiation into sperical harmonics and that only those with l=1 can express a dipole or something... could that be it?
Yes, that's correct. I'll skip the derivation and just state that the matrix element for the dipole moment transition is:
[tex]\mathbf{r}_{n',n} = \int u_{n'}^*\sum_i\mathbf{r}_i u_n d\tau[/tex]
I.e. zero unless you have a mean change in location along some axis. (which is intuitive, right?)
Using the rationale from Bethe and Salpeter, the single-electron atom wave-function is:
[tex]u_{nlm} = \frac{1}{\sqrt{2\pi}}R_{nl}(r)P_{lm}(\vartheta)e^{im\phi}[/tex]
So using [tex]z = r\cos \vartheta[/tex], the matrix element for the transition on the z axis is:
[tex]z_{nlm}^{n'l'm'} = \int u^*_{n'l'm'}z u_{nlm} d\tau = \int_0^\infty r^2 R_{n'l'}(r)R_{nl}(r) dr * \int_0^\pi P_{l'm'}(\vartheta)P_{lm}(\vartheta)\cos (\vartheta)\sin (\vartheta) d\vartheta * \int_0^{2\pi}\frac{1}{2\pi}e^{i(m-m')\phi} d\phi[/tex]
The last integral will be zero unless [tex]m = m'[/tex], in which case it's exactly 1, so [tex]\Delta m = 0[/tex], and the second integral will vanish unless [tex]\Delta l = \pm 1[/tex] (a bit trickier, turn the legendre functions into the related spherical harmonics, one of which becomes [tex]l \rightarrow l \pm 1[/tex]. Then you have from the othogonality relations of spherical harmonics that the integral will be zero unless [tex]l = l' \pm 1[/tex])
And you can of course do the same for any other coordinate and arrive at the same rules.
The [tex]\theta[/tex] equation can be integrated using the following recursion relation
[tex](2l+1)cos(\theta)P_{l,m}(cos(\theta)) = (l-m+1)P_{l+1,m}(cos(\theta))+(l+m)P_{l-1,m}(cos(\theta))[/tex]
which shows that [tex]\Delta l = \pm 1[/tex].
  • · Replies 0 ·
