Electrophoresis kinetic friction or not?
Electrophoresis separates substances based on charge and size, with mobility influenced by viscosity and resistance. In this context, lower density particles exhibit reduced movement due to increased volume and resistance, contrary to expectations that they should travel further. The discussion highlights that the resistance in electrophoresis is primarily related to viscous effects, particularly in applications like Western Blots, where kinetic friction is not the primary factor affecting particle movement.
  • Understanding of electrophoresis principles
  • Knowledge of viscosity and its effects on particle movement
  • Familiarity with Western Blot techniques
  • Basic concepts of charge and size in particle separation
  • Research the role of viscosity in electrophoresis
  • Study the principles of Western Blotting in detail
  • Explore the relationship between particle charge and mobility
  • Investigate different types of electrophoresis techniques
Researchers, biochemists, and laboratory technicians involved in electrophoresis and protein analysis, particularly those working with Western Blots and particle separation techniques.
sameeralord
Hello everyone,
In electrophoresis the least dense one moved less (other factors been the same for every particle). I'm assuming this is due to higher volume and more resistance but, doesn't electrophoresis measure kinetic friction, so the one with lowest density should move further. What kind of resistance does electrophoresis refer to. Thanks :smile:
If you are talking about, for example, Western Blots, 'friction' is manifested in terms of viscosity- the process separates substances by charge and size, and the mobility of the charged (mobile) phase depends on viscous effects (which are related back to the charge and size).
  • · Replies 38 ·
  • · Replies 41 ·
  • · Replies 20 ·
