Transistor beta(dc current gain)
The discussion revolves around the calculation of collector current (Ic) in a TIP41C transistor circuit, particularly focusing on the dependency of the transistor's current gain (beta) on collector current (Ic) and collector-emitter voltage (Vce). Participants explore the implications of varying Vce and the stability of the circuit design.
  • Experimental/applied
  • One participant notes that beta (B) varies with Ic and questions how to determine beta at different Vce values.
  • Another participant explains that for a bipolar junction transistor (BJT), the emitter current (Ie) can be set to a desired value, and Ic can be computed using alpha, which is more stable than beta.
  • Concerns are raised about the inability to set Vce to a specific value with the current circuit design, suggesting that Vce is effectively fixed to the supply voltage.
  • It is mentioned that the circuit may lead to a blown transistor if the base resistor is not carefully chosen, due to the fixed nature of Vce.
  • A participant warns that the circuit is unstable because beta varies significantly with temperature and current, potentially leading to thermal runaway without negative feedback mechanisms.
  • Suggestions are made to include a resistor between the emitter and ground to stabilize the current through negative feedback.
Participants express differing views on the implications of beta variability and the stability of the circuit design. There is no consensus on how to effectively manage Vce or the stability of the circuit under varying conditions.
Participants highlight limitations in the circuit design, including the absence of a load in the provided diagram and the potential for thermal runaway due to beta variability. The discussion reflects uncertainty regarding the best practices for setting Vce and managing current stability.
tefavolc
i am tring to use transistor tip 41c , and i want to calculate Ic ,,, knowing that ( Ic=B*Ib)
but when i try to know BETA (B) from the data sheet of the transistor i found that it vary with the collector current (Ic) and the graph show the relation between (Ic) and beta in case Vce=4 volt only,what if i ve to set Vce at different value ?.. please if anyone has experince in that field help,my circuit and the datasheet are in attach.
  • TIP41C_3.pdf
    TIP41C_3.pdf
When employing the bjt, we generally set the emitter current, Ie, to a desired value, & then collector current Ic, is computed as Ic = alpha*Ie. For a small signal bjt, alpha can range from 0.98 to 0.998, very narrow range of values, less than 2% total variation over temperature, specimen, & current level.
The relationship between alpha & beta is alpha = beta/(beta+1), or beta = alpha/(1-alpha).
The problem with setting Ib to a specific value is known as "beta dependency". The beta value can go as low as 50, up to as much as 500. If we wish to set Ic to a known stable, consistent value, we should rely on alpha, not beta.
A good text on basic electronics will show you how to do this. Also, there are many web sites dying to teach people about electronics, but if you are a beginner in the learning stage, you need to differentiate between sound advice, & heresy propagated by 2nd rate hackers, crackpots & wanna-be's. I hope this helps.
Claude
It is impossible to set Vce to anything with the circuit shown in your picture.
Or if you like Vce is permanently set to the supply voltage.
Redraw your circuit, including the load (you have not shown any load) and then we can discuss what you want to achieve.
ys Vce is set to the supply voltage which is Vcc = 9volt.
Which means that all you will achieve unless you are very very careful with the base resistor is a blown transistor.
The circuit in your diagram is unstable because beta varies substantially not only among transistors of the same type but also with temperature. As your transistor begins conducting it will get warmer increasing the beta which increases the current it conducts. If the current is high enough it will go into thermal runaway and destroy itself.
You need some sort of negative feedback to prevent that. The easiest is to put a resistor between the emitter and ground. The current is then controlled by the voltage at the base which is equal to Ie*R + Vbe.
9K
  • · Replies 29 ·
