The discussion revolves around calculating the heat released when a lake with a surface area of 8.5 km² freezes to a depth of 1.0 m, assuming the water starts at 0 degrees Celsius. The context includes mathematical reasoning and conceptual understanding of heat transfer and phase changes.
- Mathematical reasoning
- Conceptual clarification
- Debate/contested
- One participant requests help with calculating the heat released, providing a specific answer of 6.2 x 10^11 Kcal.
- Another participant suggests using Newton's law of cooling as a potential approach to the problem.
- A different participant argues that the problem is simpler than using Newton's law, emphasizing that since the water is at 0°C, there is no temperature change, and the calculation involves the volume of ice and the heat of fusion of ice.
- A chemist participant proposes calculating the number of moles of water frozen and using the heat of fusion in kJ/mol, implying a different perspective from a physics approach.
- The original poster expresses confusion about the supplied answer being incorrect, indicating uncertainty in the provided information.
Participants present differing approaches to the problem, with no consensus on the method or the correctness of the supplied answer. The discussion remains unresolved regarding the accuracy of the initial answer and the best approach to the calculation.
Participants mention various methods for calculating heat release, including the heat of fusion and the number of moles, but do not clarify specific assumptions or definitions that may affect the calculations.
